Old 03-29-2008, 02:08 PM   #1
chip46wis
73 crossmember on a 1950
Somewhere (H.A.M.B.?) I read a article about using a 73-87 crossmember on the 1950 1/2 ton using only 1/2 inch spacers for frame fit.It seems it is wider but can be corrected with backspacing rims.
Anybody done this? I happen to have access to a free 77 1/2 ton 2wd that is just sitting.
chip46wis is offline   Reply With Quote
Old 03-29-2008, 06:13 PM   #2
solidaxel
solidaxel's Avatar
Re: 73 crossmember on a 1950
Do you mean the rear end or the transmission crossmember?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-29-2008, 07:07 PM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i think he means the front suspension crossmember
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 03-30-2008, 12:02 AM   #4
55dude
55dude's Avatar
track width is to wide. i have talked to a handful of people that have done this and wish they didn't. couple of them also did it to TF trucks and said they should have used a different clip.
55dude is offline   Reply With Quote
