Old 03-29-2008, 04:40 PM   #1
70cstjr
70cstjr's Avatar
my father 70cst wants to know if this is a deal
I found this on craigslist and so far i cant find anything bad about it..It looks like a good deal just wanted some feedback, he wants to make sure if would be a good purchase
http://dayton.craigslist.org/pts/620375653.html
I have a automatic transmission that I bought in March 2007. I purchased the engine and tranny together from a 1991 S10 Blazer 2 wheel drive. I had the tranny rebuilt and installed in April 2007. This tranny has about 800 miles on it since the rebuild so it has alot of life still left in it and it was NEVER used to pull anything. I have now sold my Blazer but I thought I could use the tranny but now it just seem to be in the way so it has to go! You can contact me at 937-xxx-xxxx, leave a message if no answer I HAVE PICS IF YOU WOULD LIKE TO SEE THEM...
REMEMBER!!! This is for a transmission ONLY!!! Thanks for looking...
PROJECT CIRCUIT RIDER
70cstjr is offline   Reply With Quote
Old 03-29-2008, 05:00 PM   #2
bobthecop
bobthecop's Avatar
Re: my father 70cst wants to know if this is a deal
I would think so, a good core for a rebuild should bring $100.00. But then I could be wrong, if I needed one I'd buy it.
Happiness is towing your "new" truck home.
1972 C-10
1982 GMC (parts truck??)
1969 c10 parts truck
1969 C-10 ( my sons)
1992 Silverado 4X4 (now the boys truck)(now mine again)
2002 Tarus (my wife loves that car)
bobthecop is offline   Reply With Quote
Old 03-29-2008, 05:00 PM   #3
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Does not sound like a bad deal. Ask him for the receipt/papers of the shop he got it rebuilt at. Surely if it was rebuilt in April 2007, he'll have the receipt (depending on the shop, it may still be under warranty). If it checks out and you and your dad feel good about it - I say Go For It. Nice Find and Good Luck.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-29-2008, 05:09 PM   #4
cdowns
cdowns's Avatar
its pretty much the value of a core charge// even at less than a thousand miles if it wasnt adjusted right it could be burned weather it pulled anything or not
Old 03-29-2008, 05:44 PM   #5
dan42
dan42's Avatar
What is it that you're putting it into? Unless I'm missing something, it's a tranny out of a S-10, and unless you're putting it back into something small, it doesn't seem to be the appropriate tranny for our trucks anyways...
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 03-29-2008, 07:06 PM   #6
Huck
Huck's Avatar
If a 700R4 is installed and the throttle linkage adjusted incorrectly, it will burn out in a matter of weeks under normal driving!! They are very line pressure sensative!!!!!! Unless you are getting some kind of guarantee, I would be leary. Talk to the rebuilder and ask them what they would want to "check it out"!!
Just as an fyi, if hooked behind a small blazer with a V6 like a 4.3, it is probably the exact same 700R4 used in small V8 applications. If the rebuilder did the normal upgrades and it works as designed, it is a great trans for our trucks as most old 350's don't put out about the same HP and Torque as the 90's vintage 4.3.
So is it a bargin?? Maybe and maybe not. Get it checked out before you put up the $$$.
Huck is offline   Reply With Quote
Old 03-29-2008, 11:39 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
In 91, they still had the 2.8 in the S-10 chassis, and that tranny will NOT bolt to anything but a 2.8 or 3.1. You need to be sure that tranny came off a 2.5 or 4.3.
Old 03-30-2008, 09:54 AM   #8
cowboyup1086
cowboyup1086's Avatar
i have a rebuilt 700r4 from a 88 silverado with better internals and shift kit
cowboyup1086 is offline   Reply With Quote
Old 03-30-2008, 03:30 PM   #9
caminokid
Chevy nut
caminokid's Avatar
I was going to say the same thing. Make sure its not off a 2.8. Otherwise you got a trans that wont bolt up.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II
"Remember kids there is NO replacement for displacement!"
caminokid is offline   Reply With Quote
Old 03-30-2008, 04:56 PM   #10
70cst
70cst's Avatar
I just spoke with Curt and as you all said...this will not directly bolt up plus it's Curt's opinion the rebuilt 400 is a more bullet proof tranny for the 402BB. Sooooooooo as the famous Howie says...No Deal!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-31-2008, 04:41 AM   #11
arkracing
Weekend Warrior
FYI guys, 2.5L s-10 motors share the same bell pattern as the 2.8. The only ones that will match the V8's and I6's are from a 4.3L S-10
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 03-31-2008, 07:41 AM   #12
Longhorn Man
nope, the 2.5 has the normal chevy bellhousing (even though it is a pontiac motor). This engine predates the 2.8/3.1 60 degree V6 engines.
