Temp Gauge
Where should the needle sit on the stock (un-numbered) gauges? I just put a new thermostate in last weekend and this morning on the way to work noticed it is reading above the half way mark towards hot. W/ the old thermostate the needle always sat just above the cold tick when warmed up. Possibly the therm was stuck open and my engine was running cold...but not this morning. I installed the new thermostate last weekend and havn't noticed the jump in the temp guage until this morning. The needle never got to the hot mark, but it did bounce around a little when I hit bumps in the road.
THNX.
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun |
![]() Join Date: Jul 2003
When I purchased my '72, it had a set of expensive Autometer numbered gauges in it. The temp was indicated to be at a consistent 195 degrees. I later removed those gauges and hooked up the factory units. The temp gauge reads 1/3 of the way off the cold mark all of the time.
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... ![]() 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 03-29-2008 at 09:13 PM. |
#3 | |
Re: Temp Gauge
![]() Join Date: Mar 2008
Re: Temp Gauge
Other than going digital, does someone make numbered gauges that fit in the factory gauge plate?
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
