Old 03-30-2008, 01:17 AM   #1
ajgriffin
ajgriffin's Avatar
Dumb Question Here
I'm doing a drum swap out on the front of my truck, but I have 6-lug universal wheels. According to LMC the only disc brake rotors off for the 71-72's with 6 lugs are the 4WD ones. So does anyone know if 2WD & 4WD rotors are interchangable?
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 03-30-2008, 01:37 AM   #2
Riveted1
Tasty Cakes!
Riveted1's Avatar
Re: Dumb Question Here
You'll probably have better luck w/this in the regular 67-72 section. Oh, and I'm putting 6 lug rotors on my 2wd, got em w/my 6-lug kit from ECE.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 03-30-2008, 01:53 AM   #3
ajgriffin
ajgriffin's Avatar
Dumb Question Here
Old 03-30-2008, 01:54 AM   #4
ajgriffin
ajgriffin's Avatar
Thanks! I just put another post over there.
Old 03-30-2008, 02:04 AM   #5
chrislehr
Engine n00b
chrislehr's Avatar
Id guess the hub size may differ 2 versus 4 wheel drive on the fronts.
chrislehr is offline   Reply With Quote
Old 03-30-2008, 02:17 AM   #6
69halfton
69halfton's Avatar
i would have to agree with the previous statement.
a 4wd junkie will chime in soon i would think.
have you looking into later model trucks? im sure into the late 70's they were back to 6 lug wheels weren't they?
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 03-30-2008, 02:29 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the 4X4 disks will not fit.
You can get a conversion rotor/hub assembly from most any vendor to keep your wheels. However, personally, i would look at the price of those rotors verses 5 lug rotors avalible at any parts store, then considor swappin out to 5 lug all around.
Old 03-30-2008, 02:31 AM   #8
ed2552
ed2552's Avatar
2wds were not 6 lug again until 2000 or so, as far as i kno, rotors are probably the same. measure them and get the measurements from LMC
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 03-30-2008, 02:56 AM   #9
ajgriffin
ajgriffin's Avatar
Thanks for the info guys. I just found out that ECE has a 6 lug rotor set that's made for 2WD trucks. I was a little disappointed with LMC to find out they didn't have a tech dept to answer that question nor was the sales staff experienced enough to tell me, but maybe I'm just wishing.
I'm only going with the 6-lugs temporarily too. I've already purchased a new 5-lug rear end ($150) and everything from the spindles out w/5 lug rotors for the front ($75) from the junk yard so I'm all set to go. If the 5-lug wheels I want didn't cost $3400, I would make the switch now, but since they do I'll keep the 6 lug universal wheels until I'm ready to go all the way.
Thanks for the advice guys.
Old 03-30-2008, 03:38 AM   #10
Longhorn Man
you've just discoved one of the many many many many reasons why I (and many others) don't like LMC.
Old 03-30-2008, 06:51 AM   #11
ajgriffin
ajgriffin's Avatar
Thanks for the heads up. I went ahead and ordered the rotors from ECE. Should be in the end of next week
Old 03-30-2008, 05:27 PM   #12
LONGHAIR
Please don't double post...not only is it against the rules, it makes the subject hard to follow and show up as another hit in the search results.
Per the rules you agreed to when enrolling
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
LONGHAIR is offline   Reply With Quote
Old 03-30-2008, 08:17 PM   #13
ajgriffin
ajgriffin's Avatar
Thanks, I didn't know that before. Hopefully there isn't anything in there about giving up your first born or 50% of your income because I wouldn't know that either I'm going back to read the rules now.
Old 03-31-2008, 01:02 AM   #14
Riveted1
Tasty Cakes!
Riveted1's Avatar
Yeah sorry, I should have told you to pm a moderator to have it moved.
Old 04-11-2008, 07:55 AM   #15
Mykul
I take it that the 6 lug rotors were designed to fit the stock 70-87 spindles. If so what are the prices, part numbers and what bearings are you using?? Sorry for all of the questions, but I've been lurking for awhile.
Mykul is offline   Reply With Quote
