Addicted to Chevy
Speedometer swapping?
I have just redone my dash, but there is a problem... my previous speedo worked fine, but i bought the white gauge decals to put on a different set- now the newly installed speedo will not stay still!
say im cruising at 50 mph- every 3 or 4 seconds it will click then jump up to 65 mph then down to 40 then sway back and forth til it settles then click again...WHATS THE DEAL? only thing i can figure is that the speedo cable is binding then releasing- making it spin up Another problem is that the odometer doesnt work with this new speedo NOW HERES MY QUESTION can i swap out to guts of my previous speedo (with the working odometer) and fix my problem? |
Addicted to Chevy
Re: Speedometer swapping?
ALSO- here are a few pics i took of the dash the other morning on the drive to work
Addicted to Chevy
its not quite as bright as it looks in the pictures... just a crappy phone camera
Im gonna buy a set of those. They are sexy.
1987 GMC R1500 TBI 350 700R4 |
Awesome.. but I prefer the original one
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
#6 | |
Hope you get one so i can fix mine. Even put a new cable on mine. |
The speedo cable needs to be lubed . Remove it from the back of the speedo and pull it out . Lightly lube it and reinstall the cable into the speedo cable housing and hook it back up . That will probably take care of the problem . Frank
Born and proudly residing in a Red State ! |
In the Forgotten far North.
![]() Join Date: Jul 2007
Use a fork to pop the needles off the 2 gauges then remove the 2 face screws and swap the faces of the 2 gauges then replace the needle.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#9 | |
Addicted to Chevy
THANKS Ble |
Addicted to Chevy
got those speedo guts swapped out... RUNS LIKE A CHAMP
