03-30-2008, 09:20 AM | #1 |
STOLEN
Headliner Question
When you install a new headliner, do you use adhesive, or just the trim to hold it up? My Super looks like the factory may have used adhesive originally.
In Search Of |
03-30-2008, 12:16 PM | #2 |
Re: Headliner Question
I use adhesive to hold the liner in place before attaching the trim.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-30-2008, 01:37 PM | #3 |
its all about the +6 inches
you'll have to use adhesive, the trim will only hold it for a few days alone.
03-30-2008, 03:27 PM | #4 |
I used 3m adhesive on the back side of the liner & the roof side. I then took a piece of plywood the size of the headliner, & use that to push up on the liner. I also took a length of 2/4 and put it up against the plywood and then wedged it firmly to the floor to keep pressure on the headliner until the adhesive dried, (overnight).
1997 GMC Sierra Ext 1965 Mustang |
03-30-2008, 07:29 PM | #5 |
Engine n00b
While on the subject... did all trucks come with one, or was that an option? Mine came to me without one, but it doesnt have a single mark on the roof, either....
03-31-2008, 12:27 AM | #6 |
I have a radical idea!
No, only uplevel trucks like CST's, Grande Sierras, and Cheyennes, etc. got them. They do a pretty good job of cutting down on the "tin can-ness" (is that a word?) of inside the cab. I have thought about putting Dynamat under one for even more sound deadening.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-31-2008, 03:17 AM | #7 |
I used liquid nails on mine.
03-31-2008, 03:23 AM | #8 |
i used 2" wide Velcro with the glued back, in case I need to remove it.
It has been in for about a year and a half and is holding great.
71 GMC LWB GMPP Fast Burn 385 crate engine, T-350, Factory A/C, tilt, gauges, buckets and console changed to houndstooth bench, 411 posi. Click Here for pictures |
03-31-2008, 04:02 AM | #9 |
STOLEN
Thanks for all the responses gang.
In Search Of |
03-31-2008, 07:06 PM | #10 |
Let me high jack and ask another question along this headliner question. Is it possible to get the original chrome trim off these trucks without breaking all the plastic tabs? And do the repo's come with the tabs or are they universal so it doesn't take all the cab roof panel holes to hold them up? Thanks. Mark
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
