Power steering question
Will a 73-87 gearbox work in my '70? Mine is junk and I can get one out of a 73-87 much easier. Thanks
A sweet 2000 Deville..... |
Re: Power steering question
ttt
I vote yes.
72 Cheyenne Super 80 Silverado Blazer 2wd |
It will work and probably give you quicker steering to boot (2.5 turns lock tolock instead of 3.5). One problem (easily solved) is that somewhere along the way the hose fittings into boxes changed, if thats the case on the one you get you can either change hoses or get some hose fitting adaptors ( http://67-72chevytrucks.com/vboard/s...d.php?t=242458 ).
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I'm thinking something like the shafts are different.....??...ratio..?...lines???
Napa has different part #'s if that means anything?? I would spend the 160 dollars on a new rebuilt and be done. Otherwise pull the new..er box and compare if you got nothing to lose
'70 Pontiac Firebird Esprit '72 GMC 2500 '90 GMC V1500 '94 Dodge Cummins 2500 '02 Dodge 2500 Quad Cab Long Box 4x4 gasser ![]() Last edited by 72gmcworker; 03-30-2008 at 09:11 PM. |
