HERE.......Somewhere
When no one is around, and the joker went to the right
![]() ![]() Please let me know
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 ![]() ![]() Classics make it possible! |
He's got mean nasty FANGS!
![]() Join Date: Dec 1999
Re: I mashed the brake to check my brakes out...
Most likely you need to adjust your brakes. A pull upon braking is usually caused by the drums not adjusted equally. If it was an alignment issue it would show up anytime you are driving.
Josh
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
Also real common to have the front brake hose's collapse internally and be completely plugged. Check the left front brake hose.
Good luck. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
![]() Join Date: Dec 2006
I'd pull the drums and look for a cylinder leak or other contamination on the shoes.Look for a glazed drum,heat damage,flakey crumbling shoes etc. But get it fixed. It may just seem like an annoyance now but in an emergency stop you will want a straight stop without spinning!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Old Skool Club
![]() Join Date: Jun 2001
A leaking grease seal can make a brake grab, but if it ain't grabbing, just pulling, it is probably adjustment time. If a drum has been turned too much, it will pull to that side. If the drums are not turned equally, like both fronts the same and both rears the same, it may pull. Basically, the larger diameter drum will find that it will pull because of the different diameters.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
Here's a great site for brake problems and the fixes. I thought it was worth posting.
http://www.classicperform.com/TechBo...oubleshoot.htm
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. Last edited by VetteVet; 03-31-2008 at 01:13 AM. |
Running on empty
Oldtimers trick from years ago.................go real fast in reverse and jump on the brakes will adjust the brakes.........or at least that was what I was told
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
![]() Join Date: Jul 2004
Sticky or stuck wheel cylinder, maybe on just one side of the cylinder. That what was wrong when we had the same problem. And the cylinders and whole brake job was only 2 years old.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Thanks for all the help.
the boat guy
i mashed my brakes once to check the brakes out, then i got to pull over immediatly , remove the wheel, removed center section of drum, then the outer part of the drum. lucky i wasnt trying to avoid hitting anything. always a good idea to carefully inspect 40 year old parts that your life depends on.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#11 | |
Gone to greener pastures
![]() Join Date: May 2007
Can folks hear your V-drive screaming from 1/2 mile away? Fun things to drive & ride behind!!
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
