03-31-2008, 03:34 AM | #1 |
Phone's ringin Dude.
My brake booster sucks!
As the title says, my brake booster sucks, as in sucks all of my vacuum. When I push the brake pedal, you can hear vacuum leakdown, and the idle kicks up a bit. The brakes work fine. Should I just replace the booster or is there a rebuild kit that would be halfway easy to install?
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
03-31-2008, 03:46 AM | #2 |
Re: My brake booster sucks!
It may be hooked into the wrong port, i'm not sure which is correct, though
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-31-2008, 05:59 AM | #3 |
Replace-internal leak.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
03-31-2008, 07:14 AM | #4 |
I am a Referee of life.
Sounds like it's bad.You can get a vacuum tester and check but be aware one of the BB members had this problem and the vac leak caused him to run lean and overheat,I believe he wound up having to replace the engine.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-31-2008, 07:23 AM | #5 |
its all about the +6 inches
it was me... it shattered a piston.
you need a new booster. |
