03-31-2008, 04:04 AM | #1 |
It Is What It Is,,,,
Needing help with Tire selection
I scored a set of these Sat in Daytona,
15X8 Rallys Need a lil bit of TLC, but sweet deal @ the swap meet. Need some opinions on Tire selection Ive got 3" LCA with 2" Lower springs and the rear is flipped.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den |
03-31-2008, 04:32 AM | #2 |
Old Heap Driver
Re: Needing help with Tire selection
I just picked up the same wheels for my 80 stepside, 15X8 and 15X7. I'm looking at 235-75-15 for the rear and 215-75-15 on the front. Thats after a flip in the rear and spindles/springs in the front.
I like the stance on your truck. |
03-31-2008, 12:58 PM | #3 |
Thanks, Whats on there now are the 15X7's And 225/75/12 Front,, 275/60/15 Rear.
I kinda like the way Malo83's tires "fill" the rim but he is running 8.5" wide rims, So now the fun begins on tire selection.
03-31-2008, 08:05 PM | #4 |
275-60 x 15 back, and 255-60 x 15 front ?
Are you retired too? Nonsense! I'm in my prime |
03-31-2008, 09:59 PM | #5 |
Are the wheels all the same size (15x8)? If so, Streetstars suggestion would look very consistent.
If the wheel widths are staggered, I prefer to stagger tire sizing equally. So if you choose a 215 on the front & the rear wheel is 1" wider, the rear tire size would be a 245 or as close as possible. This keeps the tire 'buldge' equal F/R. I use the thinner van ralleys on front (6.5") w/215's & ususally put 255's on 8" ralleys on the back.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-31-2008 at 09:59 PM. |
04-01-2008, 03:15 AM | #6 |
Yes, All 4 are 15X8, Thats what I want on all 4.
04-01-2008, 03:40 AM | #7 |
Wide n'Low
Hey,
I just picked up a 2wd blazer that has a set on it, they are 15x8 all the way around and running Toyo Proxes P245-50 15's I like the way they look, and I will go out and put one on my C10 and post a pic for comparison. My truck is running a 5/6 static drop Drew
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
04-02-2008, 03:45 AM | #8 |
Oh yes please post pics.
Been looking and Im thinking on either 245/60/15 or 235/60/15. Either or on all four.
*79 C10 Short Box ST8 6 bang'r * *Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT *__--__* 79 C-10 project* .........................__ ..............._____ l __\___ ..............|_(O)_ |___(O) ] FAQ INDEX Thread The Kulture My Rat Den Last edited by Mr79C10; 04-02-2008 at 02:07 PM. |
04-02-2008, 06:29 AM | #9 |
Slugish
agree with streetstar / 275x60 on rear / 255x60 on front - will reaally fill up your fender well -close to maxing it out , unless you want a different look.
04-03-2008, 12:46 AM | #10 |
Wide n'Low
I will have them posted tonight, and will add another size (can't remember at the moment) for comparison
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired Last edited by Twisted78SS; 04-03-2008 at 08:22 PM. Reason: added pictures |
04-03-2008, 10:53 AM | #11 |
Wide n'Low
So I was of a bit on the tire sizes,
What I have on the chrome wheel is a 275-60x15 tire on a 15x8 rim w/3.5 BS The other is actually a 295-50x15 tire on a 15x8 w/4.5 BS Sorry the pics are not the best, The tires measure out as follows 275-60 is 28 inches tall and 10 inches wide 295-50 is 27 inches tall and 11 inches wide After removing some leafs and adding a flip kit the pumpkin sits about 6 inches off the shop floor, the lowest part of the truck now is the bottom of the shock mounts which are roughly 5 inches off the floor.. Hope it helps a bit
04-04-2008, 12:46 PM | #12 |
Saw a pic of the AirRide shop truck "grumpy" I think is what they called it. Saw a pic of that truck with rallys and I like those tire sizes they had on that. Think that the look I want.
04-04-2008, 04:29 PM | #13 |
'Grumpy' or 'Gumby'?
