03-31-2008, 05:53 AM | #1 |
Ball joints
Someone please tell me the difference between 63 -70, 71-72 and 73 -up balljoints. I was told the best and cheapest way to go was to convert my 69 to 73-up front suspension (a-arms, spindles, and tie rod)but it seems most drop spindles convert the ball joints to 73-up balljoint and tie rod ends anyway. By the what is different with the tie rod ends. Need advice please.
03-31-2008, 07:18 AM | #2 |
I am a Referee of life.
Re: Ball joints
The later model parts are cheaper and seem to be more readily available.You can get the spindles in any year and in a drop of 2 1/2 or 3 inch or stock height.The differences are usually in how much drop you want and pricing.Also remember that price is only a part of the equation since the weight of the spindles and brakes makes shipping quite costly.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
03-31-2008, 07:24 AM | #3 |
Re: Ball joints
I don't know the specifics, but I went with the 71-72 spindles before I realized the ball joints were $60+ each.
If I ever do this again, I will go with a 73+ front crossmember swap, because those parts are cheaper, and will probably be more readily available in the future. Not only that, but I had to use a hodge-podge of tie rod ends to get things working right with the drag link. |
03-31-2008, 07:22 PM | #4 |
Re: Ball joints
Thats what I was wanting to know. Cost? If going with 73 spindles will I have to change my 69' tie rod?
