03-31-2008, 06:53 AM | #1 |
HERE.......Somewhere
Backfire? The motor is not even a year old
The motor made a pop like sound and there was a grayish black smoke that came into the cab. I have not rawhided it none. I gave it HE77 going toward wilmington, I was passing everything on the road except near lake waccamaw, when I got towards a Citgo, an ABC store(Alcohol) I saw Blue lights and slowed Ol' Blue down. I was running 70 to 90 MPH, but mostly 75 to 80. So did this might have caused it to backfire I guess. What is Backfire, really never had any vehicle to backfire and my autotech class never covered it or mentioned. Is it over for my motor or do I need another motor?
Is my motor O.K.? Please don't bash me cause I never had this to happen to me til now.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! Last edited by 70' GMC; 03-31-2008 at 07:02 AM. |
03-31-2008, 07:07 AM | #2 |
Still Just Havin Some Fun!
Re: Backfire? The motor is not even a year old
did it just pop and smoke a little or is it still blowing smoke out of the exhaust?
a green one with some stuff done to it.... |
03-31-2008, 07:15 AM | #3 |
how many RPM's where you running? I have been in a few cars that back fire/gurgle coming off high RPMs for an extended amount time running rich would be my guess?
ΜΟΛΩΝ ΛΑΒΕ |
03-31-2008, 08:10 AM | #4 |
don't worry, the engine just needs to be tuned a bit. backfire happens wen the fuel doesnt burn quickly enough, and is still burning wen the exhaust valve opens.
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
03-31-2008, 08:58 AM | #5 |
Do you run a point dist? Check your timing.
03-31-2008, 05:37 PM | #6 |
Old Skool Club
IF you are still running points, AND the condensor is going bad, it CAN cause a popping in the exhaust while you are sitting still and giving it a little gas at a time and holding the pedal (linkage) steady. But, the points popping is different than a backfire, which was explained already, as unburned fuel in the combustion chamber when the exhaust valve opens.
But, for it to backfire as you are coming off of a higher speed, ain't unusual. There is increased engine vacuum at that time, which will pull gas/air into the combustion chamber and increase the possibility of a backfire, depending on how your timing is set....and it may be right. So, what is "rawhiding"? Do you stick a whip out the side of the window and give the bedsides a good whack to make it go faster? I may need to get me a "Fleetside Whip".....reckon LMC has 'em?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
04-01-2008, 04:32 AM | #7 | |
I was just sitting there and then turned it off and heard it make a pop sound. It is a distributor and it is black and it has Accel on it.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
