wheels ..........will they fit
Cant beat the price and i decided i dont want 20's cuz every 1 has them now .... but will they fit my 85 dropped 5/5.
http://store.summitracing.com/partde...=WVI-37-500505 http://store.summitracing.com/partde...=WVI-37-570504 |
Re: wheels ..........will they fit
I love em
2001 silverado 2wd 2003 silverado 4wd 1975 scottsdale c10 (project) |
Great choice i love rallys of all kinds,the 5 on 5 pattern will fit.I think there may be some rubbing issues if you have spindles.Someone else should chime in who knows more than me.
1980 Silverado short bed 1993 GMC 1500 LS swap 2006 Lifted Z71 Crew Cab |
I think if you run more than a 2.5" drop spindle 15" rims will rub on the lower control arm. Nice choice of wheels
Wes 1980 GMC Sierra SCSB-2WD 1986 Chevrolet C10 SCSB-2WD |
im running the stock 15 (i believe)now so i pretty sure it will be fine but, isnt that what the grinder is for? also i not set on 15x8 or 15x 7 in the front that you guys think?
#6 | |
Chevy nut
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
dont get me wrong 20's and bigger always are nice to have but no 1 sticks out any more nowadays theres even geos sittin on 22's
with the offset will they tuck
whats the offset to tuck? still got get off my butt and measure. also sorry for being with the trends. mine will have 20+ " rims. guess thats what i see in my head when i'm driving my truck.
1981 - C-10 SCSB Planning on putting this thing on it's rocker! ![]() |
It'd be alot cooler if you did
why not go with a bigger diameter in the same style? I got TONS of compliments on my steel 17s. everyone loves them and the rubber isn't that much more that 15s. I'd go with a 8" wide in the front with 4.75 backspacing all around. Thats what I have. Also if Summit can't get them just call Wheel Vintiques direct they will make you whatever you want. Same kind of rims I have.
its not that i dont want 20+ wheels just cant find what i like, i am really un decicive when it comes to wheels i d0ont want my truck just to blend in. If i dont get these i was also thing something along the lines of 20/22 but its my dd not really sure about the ride quality.
[quote=smashingchuck;2654756]why not go with a bigger diameter in the same style? I got TONS of compliments on my steel 17s. everyone loves them and the rubber isn't that much more that 15s. I'd go with a 8" wide in the front with 4.75 backspacing all around. Thats what I have. Also if Summit can't get them just call Wheel Vintiques direct they will make you whatever you want. Same kind of
i cant find any other size other than 15's Last edited by spr85gmc; 04-03-2008 at 02:18 AM. |
#13 |
1962 C-10
Those rallys are sick!
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
#14 | |
6.0 powered square
[quote=spr85gmc;2658183]
http://store.summitracing.com/partde...5&autoview=sku
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
#15 |
i really dig the 15 i know there smaller than most wheels out there now but i like them im just not sure how to make sure they fit with the offset i keep telling my self just to order them but scared they wont fit HELP....................
#16 |
15x7 w/4.00BS (F) & 15x10 w/5.00BS (R) should fit w/a mild drop (mild = 4/6 or 5/7 drops). The key will be as others mentioned: drop spindles should be limited to 2.5" to limit wheel interference. You will still need to trim the a-arms & possibly do a little clearancing of the calipers.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-04-2008 at 03:11 AM. |
