drum brake help
I can't get my drums off and I'm wondering why. I've tapped on the backs trying to knock them loose. I've tried prying them off and it feels very solid. I'm running out of patience so any ideas would be helpful...
1971 C-10, 406ci, restoration begun! 406ci sb; zero decked, bored .030, edelbrock aluminum e-tec heads, edelbrock performer RPM intake, comp 268 cam, comp 1.6 pro-magnum roller rockers, MSD street fire HEI, MSD 8.5mm wires, Holley Street demon 770, Hedman LT headers. 10.6:1 compression, Air Ride Tech bags on all 4-corners. |
Re: drum brake help
They are adjusted too far out, you need a brake spoon and possibly a small flat screwdriver, stick the spoon in and try to adjust, if it doesn't turn, take the screwdriver and put it in the slot and pry up while turning the spoon. Sorry, this is the best way i know to explain it, someone else will chime in and explain it better, good luck!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
.....I am working on it.....
Re: drum brake help
I had the same problem on my '72. I used WD40 around the center hub, then pry with a big screwdriver. Like ed2552 said, make sure the adjuster screw is loose so the pads are free.
Step Brother
Re: drum brake help
Old Skool Club
![]() Join Date: Jun 2001
Re: drum brake help
....yeah, because as the shoes and the drums wear, a lip can form at the outer edge that will keep the drums from slipping off. It's a pain at times, but it can be done. Just be patient....and back those adjuster off so the shoes can retract away from the drums. It may take a while, but it will work.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: drum brake help
if you're trying to remove front brake drums and they're still riveted onto the hub you'll need to either grind the rivets off or remove the spindle nut and the wheel bearings/rears are like they said ,adjust the shoes in and wack them real good with hammer
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 03-31-2008 at 06:18 PM. |
its all about the +6 inches
Re: drum brake help
he has a 71, so we'll assume this is rear drums he's workin on.
If the drum is stuck on solid, then it is probably stuck on the center hub. you can spray some penitrating oil on there, but the best thing, is do just smack it hard with a hammer. If you pull on the drum and it moves, but gets pulled back on... then your shoes need adjusted down and it'll slide right off. |
#8 | |
Active Member
![]() Join Date: Jul 2007
Re: drum brake help
On the pic below you have to turn the wheel opposite of the way the self adjusting lever turns it. |
Re: drum brake help
Thanks for all the info! It is a '71 so it's just the rears and i think it is the adjusting screw. If I pry, the drum flexes and then settles back on
Who's got steelies?
![]() Join Date: Feb 2006
Re: drum brake help
Coat the axle flange with Never-seize when you are done. It will save some trouble in getting the drum uff next time.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Sisyphus was my mentor!
![]() Join Date: Sep 2002
Re: drum brake help
Thats my trick too oldgold70c10. There are few things I love as much as fighting with drums on a "simple" brake job.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
Re: drum brake help
Yeah, all I was trying to do was take off the drums and paint them since I have wheels that expose them...so much for simple!
#13 |
Questionable
Re: drum brake help
i ran into the same issue with mine recently. i was amazed that simply taking a BFH and smacking 'fervently' between the lug nuts in a circular pattern half a dozen times broke it free - and this is what the Chiltons or Haynes manual suggested to break em loose.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
