03-31-2008, 08:39 AM | #1 |
HEI troubles.....
My big cap HEI is not working right, i loosened the dizzy and tried to time it, and it would not run right at all. It either idled good and revved like crap or the opposite, like it was not advancing enough. There was vacuum to the vacuum advance, but i am at my wits end. If i do get another dizzy, it will be a small cap with a separate coil, because i have had it with the big cap. What do i do from here? What is the link to that dizzy guy on ebay, skip white i think?
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
03-31-2008, 09:27 AM | #2 |
Re: HEI troubles.....
Check advance mechanism. Sounds like it frozen or rusted.
03-31-2008, 09:29 AM | #3 |
Where is that? Do i have to pull off the cap, because that is going to be a PITA because the back scews are unable to get at w/o turning the dizzy to get at them.
03-31-2008, 09:35 AM | #4 |
Yes, it's under the cap. You should be able to turn the rotor by hand a little and it will spring back. Very common on HEI. They get gumed out over time. If you want I can take a pic tommorow.
03-31-2008, 06:31 PM | #5 |
ok, yeah a pic would be great, what do i do to fix it?
03-31-2008, 06:42 PM | #6 |
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
03-31-2008, 06:50 PM | #7 |
I had a car like that once with the back hold-down inaccessible and I just left it loose.Worked fine for me anyway.
It's not enough to have vacuum to the advance unit. You have to also have a good diaphragm.So take the hose off at the carb end and suck on it to make sure you don't get lots of air.With the cap OFF you should see movement when you apply suction. The centrifugal advance system is also real basic,and as was mentioned by PONT406 you should be able to move the rotor a little and have it spring back. If this doesn't happen then take the rotor off (two screws I think) and spray some WD40 on the weights and pivot points and try and loosen up the weights.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
03-31-2008, 07:52 PM | #8 |
You can check it with a timing light without pulling the cap. Check the timing at idle with the vacuum unhooked. Then accelerate the engine. The timing should advance about 15-20 degrees as the engine speed increases. Hook up the vacuum & it should advance some more. If your vacuum advance is hooked to ported vacuum (no vacuum at idle) you might try running it on manifold vacuum. (vacuum all the time except heavy throttle). I wouldn't give up on the HEI. It is good. You can do like one of the previous responses said & leave the back fastener undone.
03-31-2008, 07:58 PM | #9 |
I can't find any marks on the balancer, and there is no pointer, so a timing light is out of the question.
03-31-2008, 09:03 PM | #10 |
Addicted to Chevy
you also have to unhook the vacuum advance and plug it with a screw or something
03-31-2008, 09:11 PM | #11 | |
laying low
Also mentioned is the centrifugal advance can sieze up over time again limiting the amount of cent advance. Either way will make them run awful. My experience with dist centrifugal advance siezure was the weights and springs on top were fine. It was the shaft that had gummed up down inside the dist. The dist had to come out and be completely disassembled to clean it and put back together. Over time the hot oil gums up the shaft inside the main shaft causing it to stick in one spot and quit advancing the timing all together. It's nothing that can't be fixed but if you are not all that familiar with the workings of a distributor you may want to just buy a replacement "complete" dist or have someone fix yours for you. I know, it's tight quarters back there. Why didn't Chevrolet ever move the distributors up front?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-31-2008, 09:49 PM | #12 |
Then people would think they were copying f**d.
04-01-2008, 12:15 AM | #13 | |
Gone to greener pastures
That'll get into the ball park.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-01-2008, 12:41 AM | #14 |
Where do I put it, in the line between the carb and dizzy?
04-01-2008, 02:13 AM | #15 |
I'm not clear following this thread where the problem is. Are you saying you can't time the engine at idle? If that's the case, I can't see where the advance factors in as there should be no advance at idle, with the vacuum plugged to set static timing.
04-01-2008, 03:07 AM | #16 |
No.
You need to be below the throttle body; like The PCV valve, power brake booster, or transmission modulator lines.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck Last edited by El Jay; 04-01-2008 at 03:08 AM. Reason: syntax |
04-01-2008, 03:39 AM | #17 | |
ed2552 originally posted
04-01-2008, 04:03 AM | #18 | |
If the problem is static timing, then the engine should be set to approximately 10-12 degrees initial and worked from there. If that's not working, then there's another problem, and you'll need to back up and verify TDC compression #1 to make sure you have an accurate timing reference. Last edited by Billla; 04-01-2008 at 04:03 AM. |
04-01-2008, 04:54 AM | #19 | |
I agree, but, he has no tab, so he doesn't know where TDC is.
04-01-2008, 05:27 AM | #20 |
No, it ran like crap, and there is no pointer. Hence the post
04-01-2008, 07:11 AM | #21 |
This is a simple problem to solve - you MUST have a reference in order to set timing. Since yours is gone - we need to make one.
1. Buy an adjustable pointer that works for your harmonic balancer size. 2. Buy a piston stop like the one below; NAPA and others carry these http://store.summitracing.com/partde...5&autoview=sku 3. Find TDC compression #1; if the stop doesn't come with instructions we can walk you through it. 4. Set your pointer to TDC compression #1 5. Set your timing With this stuff, in about an hour you can be in great shape. Once the timing is right on, if there's still a problem we can look for other causes...but you can drive yourself nuts chasing this down without a solid timing reference. Last edited by Billla; 04-01-2008 at 07:14 AM. |
04-01-2008, 06:32 PM | #22 |
Ok, once it stops snowing i will get that, if it ever does
04-01-2008, 09:45 PM | #23 |
I miss this truck.
Man, I remember living in SD and wishing it wouldn't snow in April. I don't miss that...
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
04-01-2008, 09:49 PM | #24 |
March IS the snowiest month in MN, and we are supposed to get 4-8 inches today, at least they called school off
04-01-2008, 09:54 PM | #25 |
Damn, today is april, isn't it.....
