Old 03-31-2008, 09:56 AM   #1
67chevyguy
67chevyguy's Avatar
1 piece driveshaft in 67 swb
I checked the search and couldn't find my answer anywhere.
I want to switch to a one piece driveshaft in my 67 swb. I have a th400 and 12 bolt rear end. Does any one know the length of driveshaft I will need? Also, anybody know of a vehicle that will have a driveshaft that will be a direct swap into my truck?
I would measure mine but it's 600 km away and there is a lot more selection of places to find one here than the town where my truck is.
Thanks guys
67chevyguy is offline   Reply With Quote
Old 03-31-2008, 04:18 PM   #2
Re: 1 piece driveshaft in 67 swb
They never came that way.Someone needs to measure for you.Ask whoever will make up the driveshaft how they want it measured.Usually it`s center to center of u-joint.As long as they know what points were measured from they should be fine.
Old 03-31-2008, 05:19 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Take your measurement from the centerline of the rear yoke, as in the center of the u-joint bearing cap, to the center of the splined yoke that is exiting from the tailshaft of the transmission. That measurement is the length you need. Make sure the truck is resting on the ground in its static position, not on a rack with the wheels suspended by the springs. A drive-on rack is best for this, as it offers you the best range of movement to take your readings. I'd measure mine, but it's at the body shop and it just ain't possible.
Expect to spend about $150+, in my area for a NEW fabricated one-piece driveshaft. You may be able to find one in a junkyard, but you may have to have the ends swapped-out to get it to work for you. Don't forget that it needs to be balanced.
Member Nr. 2770
Old 03-31-2008, 06:34 PM   #4
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Question Re: 1 piece driveshaft in 67 swb
the 2 piece driveshaft was only in long bed's ? wasn't it ?
I have never seen a short bed with a 2 piece , was the truck a long bed and was shortened ?
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-31-2008, 06:53 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My SWB has a 2-piece driveshaft, as did my sons' SWB.
Member Nr. 2770
Old 03-31-2008, 08:21 PM   #6
brad_man_72
the boat guy
brad_man_72's Avatar
only way to know is to measure YOUR truck, their are too many combinations of where to mount the motor, if your planning on lowering your truck, you want to do that before you get a new shaft made. best way to help the guys making your driveshaft is to have c-c measurement and bring the old u-joints or shaft with you, new yolks are expensive, they could possibly use your old ones.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-31-2008, 09:19 PM   #7
redhead69
fugedaboutit
redhead69's Avatar
sb in forward position with a th400 should be 58 1/4" for a swb truck from center to center as mentioned. If you have a slip yoke make sure you pull it out 3/4-1" for the measurement
Currently truckless
redhead69 is offline   Reply With Quote
Old 04-01-2008, 03:31 AM   #8
67chevyguy
67chevyguy's Avatar
thanks guys, my dad should be able to measure for me sometime this week unless he's working out of town.
redhead69 58 1/4" sounds about right for mine, I measured 54" from the closest weld to the slip yoke to the closest weld to the rear end and last time I was there, but I knew I was probably measuring incorrectly, I'll be sure to get an exact measurement of mine tho.
Old 07-06-2008, 04:25 PM   #9
Ford Assassin
Ford Assassin's Avatar
Updates....
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
