Old 03-31-2008, 06:26 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cab Mounts Pictures
OK while I had the carpet out of the truck I decided it was a good time to redo the cab mounts. I had to cut both front mounts off with a saw. The bushing was so rusted it was not coming out. The backside mounts came right out with no problems.
New Front:
New Back:
OK now for my Question:
I bought the kit and I have two mounts left over...what are they for you reckin'. I looked at the old ones and I put the new in like they where.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-31-2008, 06:32 PM   #2
Dano69c10
Dano69c10's Avatar
Re: Cab Mounts Pictures
I'm not sure were you bought the set from, but my set included mounts for the radiator core support, since that is affected by changing the body mounts.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 03-31-2008, 06:47 PM   #3
Andy4639
Old member
Andy4639's Avatar
You maybe right I hadn't thought of that. Evrything is lined up though.
Old 03-31-2008, 06:58 PM   #4
HOTFUN
HOTFUN's Avatar
Not quite sure what you got there but I do see the beveled edge bushings are upside down. THe wide part against the frame mount and the smaller bevel would go with the new left over washer and then the nut. But I don't remember a bushing against another bushing as it is in your picture. You might take a quick look at another original truck. Mark
'66 CST BBW swb fleet 327 fac ac
'67 CST 4x4 swb 327 stepside project
'72 Cheyenne K20 50k original
'72 Cheyenne Super K20 project
'73 Sierra swb 4x4 frame off in paint stage
'74 Cheyenne Super swb w/16k actual
'71 & 72 Cheyenne K10 4x4 swb's
'70 426 HEMICUDA conv SHAKER 4 sp Dana 60
'60 Impala conv 327 PG fac ac loaded 3rd owner
'72 GMC K2500 4x4
'59 Apache CST BBW fleetside swb 283
'73 ElCamino SS LS1 T56 true SS bucket tach
'76 ElCamino SS 52k survivor
'87 Grand National 41k True 2nd to last built in 1987.
'86 K30 454 SRW fleetside CA since new
'88 Trans Am GTA 39k bought new
2018 DEMON plum crazy @ 840HP! "Need for speed"
HOTFUN is offline   Reply With Quote
Old 03-31-2008, 07:41 PM   #5
TravisH
TravisH's Avatar
like he said, the lower sections are upside down and one set off the rear are the lower part for the radiator mounts
TravisH is offline   Reply With Quote
Old 03-31-2008, 08:08 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
yup....you need to make a few changes and use the small set for the radiator support.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 03-31-2008, 10:07 PM   #7
Green Machine
Green Machine's Avatar
Looks like you got the "generic" mounts. They actually are 73 up mounts IIRC. Now I guess a lot of people use these, but I only use the original style replacements. LMC, Classic parts of america, or check board vendors here. Get the "correct" ones and sell the others to someone else. There should be a square washer on the front mount between the cab and the mount too, usually, sometimes not, sometimes two. depend on how fenders line up with cab, but I always start with one square washer up there. Also check the bolts that come with the kit and make sure that they are at least grade 5 (3 line), the originals were grade 5, only 4 bolts holdng the cab on, I don't want some cheap grade 2 bolt on there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-31-2008, 10:44 PM   #8
Hart_Rod
Hart_Rod's Avatar
Here's some instructions from the energy suspension website:
http://www.energysuspension.com/pdf_instruc/17016.PDF
Hart_Rod is offline   Reply With Quote
Old 03-31-2008, 10:51 PM   #9
68gmsee
Active Member
68gmsee's Avatar
I took these pics for reference on my 68. I'm going to replace mine in a few weeks.
Front and rear
68gmsee is offline   Reply With Quote
Old 03-31-2008, 10:56 PM   #10
c10crazy
Like a Rock!
c10crazy's Avatar
I would leave them alone. They lasted almost 40 years, so big deal you have them backwards they may only last 30. Were they hard to do?. Can I do this without removing carpet?
69 LWB
Runs great - work in progress
Mess with me and you mess with the whole trailer park!
c10crazy is offline   Reply With Quote
Old 04-01-2008, 05:50 AM   #11
70c10
67-72 Addict!
70c10's Avatar
I need to replace all of mine also!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-01-2008, 05:59 AM   #12
stope4
Bot trying to be picky but you may also want to apply the correct torque. I think these are like 60 or 70 lbs. They should squish a little.
stope4 is offline   Reply With Quote
