03-31-2008, 08:21 PM | #1 |
Cargo Light mounting bolts
I am replacing the cargo light on my 72, and the rubber covered nuts on the inside are destroyed. Where can you get new mounting rubber grommet nuts to replace theses. I have a new reproduced cargo light and it did not come with mounting bolts.I did a search and found that these have to be insulated so that it does not ground through the housing. Any input?
Thanks Ron
1972 C30 Cheyenne Super 1971 C10 (Parts truck) |
03-31-2008, 08:32 PM | #2 |
Currently Blazerless
Re: Cargo Light mounting bolts
Ron, I found them at the local Ace hardware store.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-31-2008, 08:33 PM | #3 |
What you need are called well nuts and I think you can get them at Ace Hardware or even NAPA.
03-31-2008, 09:55 PM | #4 |
LMC part 30-0830
04-01-2008, 03:24 AM | #5 |
I got mine at ACE Hardware but the nuts were 10-32 so I bought stainless at ACE with the 10-32 threads. (Stock bolts are 10-24).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
06-08-2008, 09:21 PM | #6 |
Not a bad nut after all..
Is this the correct style of part (first picture)? The ones in my pickup look like they have a bulb (second picture with red text) on the inside which retains them to the cab, but does the bulb occur when they are tightened into place?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 06-08-2008 at 09:40 PM. Reason: add picture of old part |
06-08-2008, 10:07 PM | #7 |
Just another option for you is some nut rivets. I used them (harbor freight) and worked perfectly. Just a thought for ya.
06-08-2008, 10:50 PM | #8 |
badpeanut,You are correct at that assumption!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
06-09-2008, 11:01 PM | #9 |
Thanks, I found well nuts at the hardware store today.
What light bulb does the cargo light take (I can't find it listed in my owner's manual, service manual, or overhaul manual)?
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
06-10-2008, 04:21 PM | #10 |
It's 1076 on the light bulb. On the mounting bolts, you can also find them at Golden State Parts. They are exactly the same as the original one's.
1972 Chevrolet Blazer 4x4 (Almost done stay tuned) 1970 Chevrolet Pickup Longhorn CST/20 (SOLD) |
