Old 03-31-2008, 10:45 PM   #1
BrooKLyn
BrooKLyn's Avatar
lift after lower ?
Is there away i can lift my truck aboout 2inches after i put a flip kit on ?
BrooKLyn is offline   Reply With Quote
Old 03-31-2008, 10:54 PM   #2
1980GMC
1980GMC's Avatar
Re: lift after lower ?
I dont think so. The only way I can think of is to use lift leaf springs.
Wes
1980 GMC Sierra SCSB-2WD
1986 Chevrolet C10 SCSB-2WD
1980GMC is offline   Reply With Quote
Old 04-01-2008, 03:07 AM   #3
benoit454
Chris
benoit454's Avatar
why put in a flip kit if you want it raised up 2 inches afterwards?
Maybe do a shackle and hanger kit for a total of 4 inches drop instead of 5-6 with a flip kit, and most shackles have multiple holes which would raise or lower it more, or if you want you could leave the stocker hangers on the front and only get a 2 inch drop?
Just some idea you might want to consider, instead of lowering with a flip kit then raising it back up.
Chris
GIT R DONE!!!!!!
Check out all our rides,
Old 04-01-2008, 03:51 AM   #4
tds
they do make lift shackles. not very much lift but they do have em out there.
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 04-01-2008, 05:46 AM   #5
Prerunner1982
Prerunner1982's Avatar
By stock design a "lift shackle" would lower the truck, due to the inverted position of the shackle. However, Off Road Design (www.offroaddesign.com) makes a shackle flip hanger that can provide 2.5" lift upto 4" lift with stock leaf springs, which will provide a softer ride than lift springs.
This does seem counter productive to me. But may provide the ride height you want with the ride quality as well. Retaining the stock springs but keeping the axle far enough from the frame to still have some travel. With the axle above the springs this should also lessen axle wrap.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 04-01-2008, 05:57 PM   #6
BrooKLyn
BrooKLyn's Avatar
already slammed it cnotch just seemed like 2 inchs lift would be little better
Prerunner1982 thanks ill check the site
Old 04-01-2008, 06:07 PM   #7
hotrodhomi
hotrodhomi's Avatar
Four link and bag it.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-01-2008, 06:11 PM   #8
cochino12
It followed me home?
cochino12's Avatar
I used 2" shackles to bring the rear of my blazer up a bit.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-01-2008, 07:24 PM   #9
Bad Karma
Magnificent bastard
Bad Karma's Avatar
You can put a 2" add-a-leaf on it, but it will stiffen up the ride, which may be good or bad for you. I did this on my Suburban, because the flip put the axle on the frame, the extra leaf lifted back up a little and gave it a great ride.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 04-02-2008, 06:18 AM   #10
slugish
Slugish
Wink Re: lift after lower ?
Air shocks/ but would be pretty dang stiff.
slugish is offline   Reply With Quote
Old 04-02-2008, 06:43 AM   #11
bigblock79
67 Chevy Stepside
bigblock79's Avatar
i have seen it done. you take the rear shackle and you cut it right in the middle and take about 1 1/2 inch out and weld it back togather. i din't do it. but have seen a member do it and it looks good
1967 Chevy stepside
1976 BIG DOOLEY 454 turbo 400 4:11
bigblock79 is offline   Reply With Quote
