Carb Identification
Well, I'm having a hard time identifying this carb. Can anyone tell me what it is. and whether or not it's worth rebuilding or just replace?
![]() ![]() ![]() Need any more specific pictures just ask. Also i thought that the 250 engine mounts were staggered and not straight across from each other. Or is it the other way around? Last edited by Mister laugh; 04-01-2008 at 05:26 AM. |
Re: Carb Identification
Obviously it is a Holley 2 BBL
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
#3 | |
Gone to greener pastures
![]() Join Date: May 2007
Try going to the Holley site and searching for that "tab" number. Or, if you can find any other numbers, enter them.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#4 | |
I forgot to mention, search Holley for the numbers on the carb body.
It looks like an old 1900 series Holley from the fifties. Check out this link for a manual:
http://www.tocmp.com/manuals/Carbs/H...IHC_53B24.html Why do I save links for IH carbs from the fifties? I have no idea!
68 GMC 64 1/2 Mustang convert A bachelor's life is no life for a single man." - Samuel Goldwyn |
its all about the +6 inches
250 mpounts are straight across, 292 mounts are staggered
The only numbers i can find are the ones i took the picture of. They dont come up in the holley website and that tab is just a rebuild tab from autoline I'll grab a pic of it tho if it helps.
I found a number under the fuel line. 2r-3864
which leads me to this carb http://www.carburetor.ca/carbs/kits/CK006.htm it is definitely not that carb, I'm thinking it is a holley 1900 seriesbut cant get any further than that. |
