Old 04-01-2008, 06:39 AM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Relocating proportioning valve
I want to make a bracket to mount my proportioning valve to the frame.
I’m thinking all it will require is the lower lines to be cut and flared. And the uppers replaced with longer ones. Is this hard to do? Is it a double flair? Any insight on how to do this/where to put it would be helpful.
Ive seen this done here before, but nothing came up with a specific search.
And a search with just proportioning valve....well, just tons of info
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-01-2008, 07:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Relocating proportioning valve
I don't see a problem with doing that. Yes, they are double flares so you will need a flaring tool that does doubles. If you have never made double flares before you might want to find someone that has, to help you the first time.
LockDoc
Leon
Old 04-01-2008, 07:40 PM   #3
67chevemall
67chevemall's Avatar
put the whole thing on the frame, under the drivers seat....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 04-01-2008, 08:53 PM   #4
tcb-1
Nothing to see here.....
tcb-1's Avatar
I've 45 degree-flared several lines on my truck lately and it's not too hard...... but you need to practice as it first.
AND buy a quality flaring kit and tubing bender. it pays to spend!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-01-2008, 09:00 PM   #5
Huck
Huck's Avatar
ALL brake lines are double flared. The other thing to allow for is the brake light failure line that plugs into the proportioning valve. In doing this be aware that bleeding the system can be a real PITA so have patience and allow for several attempts--you also need to pull that front pin on the prop valve to get the right bleed from the front. Huck
Huck is offline   Reply With Quote
Old 04-01-2008, 09:45 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
Double flares can be a royal pain. Another option is to buy lines at the auto parts store. They are double flared on both ends, and come in lengths that are multiples of 10".
You will also need a tubing bender. Without one you will kink the tubing. They are two styles. One has a round mandrel to bend the tube around, the other is a spring, similar to an old screen door spring. You slide the tube in and bend away.
The spring style is usually cheaper and works pretty good for occaisional use.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 05-08-2011, 02:35 PM   #7
azsmokey
I am running into a similar situation with needing to relocate the prop valve due to wheel well clearance issues in a custom project. How did everyones modifications work out?
azsmokey is offline   Reply With Quote
Old 05-08-2011, 03:05 PM   #8
Slick67
Sofa King Crazy!!
Slick67's Avatar
I put mine on the frame first time around and here are a couple of pics of the outcome. I made the bracket from aluminum bar stock and painted it.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-08-2011, 03:26 PM   #9
5150.4.67
You could put it on the front crossmember, like the 73 and later......
5150.4.67 is offline   Reply With Quote
Old 05-08-2011, 06:13 PM   #10
brad_man_72
the boat guy
brad_man_72's Avatar
I put mine inside the framerail about even with the oil filter. I don't recommend this unless the engine is removed. It sure does clean up the engine compatment.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-08-2011, 07:46 PM   #11
Jeffs70
Jeffs70's Avatar
great info to know, As I am planning on doing this to mine.
Jeffs70 is offline   Reply With Quote
Old 05-08-2011, 08:44 PM   #12
Autoblueprint
Autoblueprint's Avatar
s/t
I do this type of task, i.e., make steel lines ( mostly for fuel applications ) on a fairly regular basis, I'm experienced at it, I have a wide assortment of bending tools and a high quality flare set...and let me say that each one is a challenge...it is the type of task where one really has to take their time...one wrong bend...one flat spot ( the diameter MUST remain ROUND otherwise it creates a RESTRICTION ) and if you mess-up...it's trash and you have to begin all over again. To do this type of task, CORRECTLY, one needs to be experienced at it.
I'd suggest using RUSSELL PERFORMANCE COMPETITION BRAKE HOSE :
http://www.russellperformance.com/mc...petition.shtml
This stuff is not cheap...but for what you will spend on tools alone...you could buy the hoses you need. BTW: bending tools for STEEL line NEED to be high quality...in this case Harbor Freight stuff will not make the grade...needs to be Proto, Snap-on quality.
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
