Old 04-01-2008, 06:11 PM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
My K5's tires had an allergic reaction causing swelling
My K20 is decommissioned for a while and I will have to yank it's front tires anyway, so I thought, why not throw them on the K5 for a while.
I think these pics show why 4" of lift is generally considered to be inadequate for 35"s The fender flares that I haven't yanked yet make the clearance look worse of course but obviously would have contact if the K5 was used off-road with these tires and no trimming. The front lift is 4" springs while the rear lift is a 2" block along with custom spring perches on the 14 bolt ff.
Here are a couple comparison pics with the smaller tires that measure 31".
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-01-2008, 06:16 PM   #2
fun in dirt
fun in dirt's Avatar
Re: My K5's tires had an allergic reaction causing swelling
Those look alot better to me. At least width wise; the narrow ones make it look so top heavy. What's the matter with the K20? I really like that truck - stylish yet functional!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 04-01-2008, 06:25 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
The K20 puked it's upper input shaft bearings after getting low on gear oil - the Rockwell transfer cases are notorious for that and I screwed up and didn't check my leaky transfer case before it got to low. I usually add some every 5-6 months and just got lazy this time. Anyway, it's transfer case will be replaced with an NP205 and while I'm at it, I'm going to move the motor forward a bit so I can get the body lift down to a more friendly 2" and for good measure I will also slap in a Dana 60 front axle that I bought in December of 2006.
Old 04-01-2008, 07:28 PM   #4
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
I agree! On all counts.
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 04-01-2008, 08:58 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
The wheels look good on the Blazer. You know you'd rather drive the Blazer than the K20 anyway...
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-01-2008, 09:03 PM   #6
Jtrux
I'm a poor spectator
Jtrux's Avatar
Sounds like it will be a nice build.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 04-01-2008, 10:39 PM   #7
DURRTY
USMC
DURRTY's Avatar
It looks good, actually looks good either way, the smaller tires fit better look like the belong on the blazer, as something that would have been used when it was made.
unless it had 3-5 more inches of lift the get rid of the 31s
is that a D60 on the blazer?
Semper Fi
DURRTY is offline   Reply With Quote
Old 04-02-2008, 12:28 AM   #8
Yukon Jack
Post Whore
Yukon Jack's Avatar
Nope, I swapped in the axles from a 3/4 ton parts truck to get the K5 roadworthy. 3/4 ton Dana 44 and 14 bolt ff with a Detroit Locker.
Old 04-02-2008, 12:45 AM   #9
68,69 K20
They call me the Breeze...
68,69 K20's Avatar
The tire/rim combo looks great on your rig. I like old school skinnies, but the 35's look awesome.
Good luck repairing the K20, looking forward to that 205, and D60 swap especially, keep us updated.
Mike
69 K20
"Beer is proof God loves us and wants us to be happy"....Ben Franklin
68,69 K20 is offline   Reply With Quote
Old 04-02-2008, 05:31 AM   #10
I like the skinnies better.I just like that look on your Blazer.
Old 04-02-2008, 06:12 AM   #11
jrdv
jrdv's Avatar
I agree with Special-K, the skinnies look best on your blazer. Of course I'm a little partial to skinny tires!!
john
jrdv is offline   Reply With Quote
Old 04-02-2008, 07:00 AM   #12
AJs72K5
AJs72K5's Avatar
I said this elsewhere already,but I'll repeat it...the 35s look great. Save the skinny tires for your bicycle
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 04-02-2008, 07:44 AM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
I kinda like the look of the 35"s on it but it would really need a 6" lift if those tires were staying on it. My K20 will have none of that, so the K5 better not get used to these tires!
Old 04-02-2008, 08:12 AM   #14
BLUE THUNDER
BLUE THUNDER's Avatar
The Blazer looks awsome with the 35's. I would def get rid of the flares. I took them off mine. Looks a whole lot better. Later Mario.
BLUE THUNDER is offline   Reply With Quote
Old 04-02-2008, 10:26 PM   #15
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
I like both,but at this stage in it's life I think the steelie set looks better.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-03-2008, 02:18 AM   #16
70rs/ss
70rs/ss's Avatar
4X4's look tough with steelies. Billet, alum, chrome just don't say, "I'll eat you if I have to!"
70rs/ss is offline   Reply With Quote
Old 04-06-2008, 02:22 AM   #17
Mike C
Mike C's Avatar
Sorry to hear about the truck Mark...
But I have to say stick with the big meats. I'm still running my 4" lift with my 36 12.5 16.5s. I trimmed the front of the rear quarters and moved the 14 bolt back about 3/4" by re-drilling perches. It is now centered in the opening and looks much better. (I had to move it back anyhow to get enough travel on the rear CV shafts splines.)
On the drivers side where my fender is the right shape, no rubbing for street driving, but the f'ed up pass fender does. (PO had poor repair done pre-1977 when we got it!) But it will be replaced soon. I'm thinking about doing some cutting and welding on the front fenders so that they are symmetrical instead of hooking in. Should have no problem running 35's with 4" lift.
My rims have 4 1/2" bs which helps. Because the 3/4 ton axles are wider than the 1/2 tons, overall track of the truck is pretty much same.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-06-2008, 02:24 PM   #18
Yukon Jack
Post Whore
Yukon Jack's Avatar
Drove the K5 for the first time with these tires and noted the driver tire in hard right turns was rubbing on the drag link end. Other than that the passenger rear rubbed on the rear edge of the fender flare a bit when I'd hit a bump. No big deal as these tires won't be on here long.
What I find interesting is I didn't have the drag link rub back when my 69 had just a 4" lift and these tires. Maybe that has something to do with the K20 having the closed knuckle axle which forced me to use the adjustable drop drag link while the K5 has uses the modified steering arm to compensate for the lift.
Old 04-10-2008, 03:16 AM   #19
griesel72
griesel72's Avatar
maybe i'm off in left field, but i really like the 8 lug steel wheels and old mud tires, just something different, i guess, and they kind of match the "look" of your K5
1969 K10 Custom 10
1997 Z71
2006 Volkswagen Jetta TDI
2006 King Ranch
1980 Wife
griesel72 is offline   Reply With Quote
