04-02-2008, 02:08 AM | #1 |
Driveshaft spline stuck in yoke.
Hey I was just wondering if anyone had an idea of how to free up a drive shaft. It is the stock rear drive shaft and where the splined end goes into the yoke it will not slide. First it was stuck all the way out and I pumped a whole bunch of grease in it. Then I put a small rachet strap on and forced it down. It shot a whole bunch of grease out and now it won't come back up. I don't even know where to start on this any ideas. -Jason
- Jason Orange Crush - 1969 K5 Blazer CST 4WD MONEY PIT 1975 CJ5 Renegade - Levi's Edition - 304 V8 original paint |
04-02-2008, 02:50 AM | #2 |
Re: Driveshaft spline stuck in yoke.
Sounds like it needs to twist the opposite way that jammed it up. Bolt one end back up, and twist the other end till it frees up. It needs a new spline if this works.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
04-02-2008, 05:17 AM | #3 |
I'm guesing that is not a replacable part? With my luck. What will I have to heplace to make that happen?
04-02-2008, 05:27 AM | #4 |
The grease is making suction is what it sounds like.Heat it up to melt the grease down.If it was tight before you compressed it it is probably twisted and may not seperate.
04-02-2008, 03:33 PM | #5 |
If the spline is striped, a driveshaft shop could put a new spline and slider on it for ya.
04-02-2008, 08:03 PM | #6 |
Everything is work in progress
Unscrew the zerk and put your air nozzle in the hole, air it up while someone pulls the two apart.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome |
04-02-2008, 09:30 PM | #7 |
get a 3rd person with a base ball mit
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
04-03-2008, 04:04 AM | #8 |
I got it fixed guys I had ruined the yoke thing that slides over these spines. I got it all ready to put in. It just got fresh spicer u joints and is being rattlecanned black right now. Thanks for all the help, I wouldn't even have know where to start. -Jason
04-03-2008, 03:35 PM | #9 |
Did you get a new slider/yoke?
Did you have to take it to a driveline shop?
04-04-2008, 05:13 AM | #10 |
Yeah I had to get a new slider yoke. It was ruined. They charged me $75 bucks to install and get the new parts.
04-05-2008, 10:12 PM | #11 |
That was cheap, good luck with the new one.
