04-02-2008, 02:10 AM | #1 |
weight of a 68 1/2 ton
does anybody know the ballpark waight of a 68 short fleet 2wd with a small block?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
04-02-2008, 02:14 AM | #2 |
Re: waight of a 68 1/2 ton
What i've heard, about 5300. To know the weight of your truck fo' sho', go to a steel place and put it on the scale, they may charge like $2 because they aren't getting anything in terns of steel, but if they charge anything it will be cheap
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-02-2008, 03:55 AM | #3 |
The 67-72 2wd trucks tend to go around 4,000 lbs curb weight. A full tank of gas, auto, air, 4x4, long vs short bed can all change the curb weight. A loaded 3/4 ton 4x4 can go 5,000lbs+
04-02-2008, 04:16 AM | #4 |
its all about the +6 inches
plan on 4000 pounds.
04-02-2008, 04:20 AM | #5 |
Saving 1 truck at a time!
GM Restoration Guide lists the CE as 3640 curb weight and the CS as 3495.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-02-2008, 04:41 AM | #6 |
while true, those are dry weights, with no options. A tank of fuel, 5 quarts of oil, 2 gallons of coolant, a spare tire, rear bumper, power steering and brakes, A/C reminants... it adds up quick.
04-02-2008, 06:42 AM | #7 |
The grain elevator or the local landfill are where I go to get scaled.
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
04-02-2008, 06:51 AM | #8 |
He was in washington, i don't know what's out there for grain elevators, but i would use my local co-op for my truck, too
04-02-2008, 07:01 AM | #9 |
I have a radical idea!
My '69 C/10 SWD fleet with a 350 and TH350 weighs around 3850#.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-02-2008, 08:15 AM | #10 |
Gone to greener pastures
Go to your local quarry.
If you don't need an "official weight" with paper work, they'll usually just let you roll up on the scale & get a weight. Most of them have a digital, outside display. Just remember to take a pen & paper so you can write it down.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-02-2008, 08:32 AM | #11 |
Oil trash and damn proud of it
Weigh scales, too. Usually their scales are just large enough to get all wheels on it. My 72 is 4000-4100lb, without me in it, quarter to half tank of gas, spare tire, rear bumper, no a/c, power steering, with toolbox, and maybe 50 pounds of misc crap in it. According to the scale at the junk/scrapyard I used to work at, so god knows how that scale could have been rigged.
Not as bad as my 97, with gear and tools, it drives everyday at about or a bit above the 6,000lb mark. half ton truck.
Mark 1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift 1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze 2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons Some of my pics http://s107.photobucket.com/albums/m294/69-350/ |
04-02-2008, 09:02 AM | #12 |
The easiest way here is to go to the transfer station (dump) and they will weigh your truck before and after you dump your garbage...or just charge you $20 for the minimum.
04-02-2008, 02:04 PM | #13 |
truck stops too. Pilot stations are supposed to be real acurate.
02-24-2009, 08:24 PM | #14 |
Barrito Loco Diablo
Re: weight of a 68 1/2 ton
Yikes... I get my tag renewal form in the mail and they have my truck listed as weighing 8000 pounds... Wow. I think there's an error. 72' GMC C/2500 long bed. stock 350.
02-24-2009, 08:36 PM | #15 |
thats probably your GVW. The theoretical weight of your truck + full payload.
8000 pounds sounds about right... maybe a bit heavy. |
02-24-2009, 08:37 PM | #16 |
resident oilfield trash
My title says 3600
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
02-25-2009, 09:00 AM | #17 |
I weighed my stepper just after I put the V8 in a few years back. I had steel rally wheels, oak bed floor, original steel bumpers, drum brakes, and a loaded down tool box in the floor board and mine tipped the scales at CO-OP at 3560 lbs. That's without my big butt in it. With the aluminum wheels, aftermarket bumpers and no tools in the floor, I would guess about 3450 lbs. now on mine.
02-25-2009, 09:18 AM | #18 |
I just went to the dump the other day, and the scale there said my 69 1/2 ton short wide weighed 3942. It was 39 and some change.
