04-02-2008, 02:38 AM | #1 |
Gettin By on Gettin By
What is this hose for??
Well got a tank for relocation. But what is the 3rd small hose for??
I get all the rest. Filler, vent, fuel pump, fuel return, but can't figure out the last one. It came out of a 85ish suburban. Maybe fuel rail return in addition to the pump return?? |
04-02-2008, 02:40 AM | #2 |
Re: What is this hose for??
That would be a good guess, just cap it and it shouldn't give you any problems
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
04-02-2008, 02:41 AM | #3 |
Active Member
Vapor canister return? Pull the assembly and see what it does/where it goes.
Sonny New Project: 67 Small window SWB 2006 Crew Cab Silverado LT Last edited by Sonny; 04-02-2008 at 02:42 AM. |
04-02-2008, 02:43 AM | #4 |
When in doubt, remove the problem. I was planning on capping one of the three. But the Eeny Meeny Miny Moe process as layed out in my chilton manual didn't seem to fit long term plans.
Eh, one outa three ain't bad. |
04-02-2008, 02:54 AM | #5 |
Here's the under side. Looks like your right. Some sorta vapor return off the throttle body. Seems it just dumps into the main body there and out that little pin hole on the right.
04-02-2008, 02:58 AM | #6 |
Do the Dew!
04-02-2008, 03:01 AM | #7 |
I agree with the others, it goes to the charcoal canister.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
