![]() Join Date: Apr 2007
Too little tank?
Ok here's my dilemma...
For my K20 build... I bought a great aluminum fuel cell from FuelCellGuy. It's 18 gallon with a Walbro Fuel pump, and sending unit. It cost $700 and I have installed it but that's it, never been filled. I'm getting worried that 18 gallons is too small a tank for my build (fuel injected 383). What do you guys think? I'd love to have at least a 25 gallon tank, but what are my options? Other than a blazer/suburban tank, are there any non-custom tanks that are somewhat plug and play? Any advice/info is appreciated! Thanks, -Tim
Maj USAF 71 K5 Blazer CST 72 K20 HT383 NV4500 Mass-Flo EFI 71 K10 LWB 52 Dodge Power Wagon 67 Dodge WM300 Power Wagon 48 Dodge WDX Power Wagon My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=239487 |
its all about the +6 inches
Re: Too little tank?
that's still 180 mile range figuring 10 MPG which I hope you do better than. Many of the 67/68 trucks came with a 17 gallon unit stock.
Where is the K20 build going? You making a boat puller? Weekend cruiser? Rock crawler? Stump puller? If a Th350 is in your plans, give yourself 30% more highway range and go with a 700r4. That would be the same as a 23.4 gallon tank (30% larger) if you do most of your driving down the slab not pulling anything.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
I already put an NV4500 in it and it has 3.42 gears. It is going to be a daily driver and it will get worked, but much of it will be long highway trips. Not 100% sure I want to swap it out, but I'm thinking I'm not going to be able to pass many gas stations...
A bigger tank won't give you enough more range to go through the hassle of sending it back and all of that
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
![]() Join Date: Mar 2008
I am with you Captain, thats why I am staying with dual tanks.
![]() ![]() ![]() 1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
#7 | |
Besides, with fairly large mud tires and the 3.42... the 700 would probably drop the RPMs into bogging down rpms, causing worse MPG. |
Too many decisions to make...
He already has a 5 spd. manual w/ OD, so he is good on that
#10 | |
What size tire do you plan?You are lifted 2"?IIRC
I get 12 mpg in my`72 K/20 with a 400,4spd,4.10,and 35s.I also get 12 mpg in my`72 K2500,350,TH350,3.54(?),and 33s.Both about empty and running Edelpuke carbs.That`s 8.5 gallons in 100 miles.Is my math corret? ![]() How about sneaking another tank in there somewhere?A saddle tank with a wheelwell filler.
#12 | |
Gone to greener pastures
![]() Join Date: May 2007
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
#13 |
Out of the carpool lane.
I'm really wanting to buy a tank like that and would offer to buy it off you, but at that price, I'd need to buy exactly what I wanted- a 20-24 gal tank. Perhaps you can live with it and just carry a 5 gal fuel can for those long trips- for just in case.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#14 |
Good point about cruise range.I`ve traveled cross-country several times in these trucks (even once in one with 14.50/37s and 4.57s) and stopping every few hours for gas always seemed about right for one need or another.Helps keep from getting zombified,as well.It`s alot cheaper to fill a smaller tank (dumb logic
#15 | |
20 gallon tank in a Ford van with a 460 cu. in. engine. Dumped 12 gallons in in No Where, South Dakota. Limped in to Wall, SD and waited for the stations to open. Good time for a nap. Then we get to Dubois, WY where my friend had a 66 Chevy with 4.56 rear end gears. We drop my dad and another older gentleman off in town (6000 or so feet) so they could get aclimated to the high altitude for a day. We then proceeded up to the trail head to have a look around. My friend grabbed a jerry can and stops at some po-dunk gas station on some reservation. He fills his seat tank up until it spilled out then filled the jerry can. That truck didn't have enough range to make it in then back out to that station without using that extra 6 gallons. That being said, I HATE using jerry cans like this. You spill and smell like gas and you are usually doing something like going elk hunting or fishing - two places you don't want to smell like a filling station. Look for a saddle tank. Instead of using that ugly pop-rivited door weld in a nice door off a newer truck. It won't distract from the lines of the bedside. If you don't like it hanging down an inch or two like the vintage saddle tanks do, modify it. Or get one and use it as a template and make another aluminum one that matches your back one only doesn't hang down like the vintage ones.
#16 |
I had that same exact tank from fcg on killer. Killer was fuel injected and i still found myself stopping for fuel way to often. I'm having a 23 gal built for my next truck! Not blaming fcg as the product was exceptional i would just like a little bigger tank for my personal needs!
R.I.P. Killer 71 10/26/07 |
#17 |
I left the tank behind the seat but will not fill it unless I go on a long trip. I have a total of 40 gal capacity and if I can get this truck to 10 mpg that will give me 400 mile range.
69 Chevy 4x4 383 Power ![]() |
#18 | |
Trucks N Tranzams
I am going to use a 31 gallon tank from from an 87 Blazer with fuel injection in my 68 longbed. I got lucky at the local pick and pull and got the entire setup with the sender, pump, skid plate and everything. The distance between the frame rails is the same as our trucks. I drilled the rivits out and got the frame mounts and straps for the tank as well. I should have gotten the fuel filler too but I ran out of time. If you can't find a tank from a junk yard, a new one can be had from CSK auto parts. Here is a link. http://www.partsamerica.com/ProductL...hfor=Fuel+Tank You can also get the sender and pump from them too. Here is another link. http://www.partsamerica.com/productd...ype=52&PTSet=A I am pretty sure Rockcrln used this setup in lowbuk. Check his build thread. PM me if you have any questions.
![]() '68 Chevy LB 383 TH400/GV/373 posi '56 Chevy 4WD SWB '64 Chevy short stepside '79 Trans Am 455/TH2004R/12blt/4whldisc 95 Kia (Wifes car) 2002 S-10 extended cab pickup "God punishes small sins immediately" |
#19 |
40 gallon sub tank in my swb and the filler is now where it belongs. on the left side
common sense isn't so common anymore |
#20 |
Trucks N Tranzams
Wow! thats 244 lbs when its full. Must really help for traction in the snow and ice.
#21 |
Post Whore
![]() Join Date: Feb 2000
Fuelcellguy took care of me with this monster
![]() ![]() It is very painful money-wise to fill up and I doubt you want something that big in the bed of your truck, but as you know, he can build anything so your options are pretty wide. I would sure give some consideration to a saddle tank like mentioned above since you already have that great custom tank installed. I think my tank holds about 35 gallons.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#22 |
I go about 180 miles on 14 gallons of fuel under normal driving conditions. I've gotten 230 miles out of a tank on the highway. I have a blazer tank and I've run it dry twice. Barely 17 gallons to fill it up
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
