Old 04-02-2008, 05:00 AM   #1
whitelightenin69
whitelightenin69's Avatar
wheel hop
anyone ever had a problem with wheel hop with trailing arm supension
whitelightenin69 is offline   Reply With Quote
Old 04-02-2008, 07:06 AM   #2
Cyclone44
Step Brother
Cyclone44's Avatar
Re: wheel hop
I haven't and I have wasted alot of tires with my trucks...Never the first hop
Cyclone44 is offline   Reply With Quote
Old 04-02-2008, 07:41 AM   #3
Mint68
Mint68's Avatar
Re: wheel hop
I was riding in BurnoutNova's 67 a couple days ago and it started to do it. He may post, but he said it was the first time he has had it happen.
Mint68 is offline   Reply With Quote
Old 04-02-2008, 08:11 AM   #4
El Jay
Gone to greener pastures
Re: wheel hop
Never had the problem; and I've smoked them a few time just for kicks & giggles.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-02-2008, 08:22 AM   #5
Ackattack
Ackattack's Avatar
Re: wheel hop
I would guess if you're getting wheel hop with trailing arms, your shocks are shot.
Now let me tell you about wheel hop with leaf springs
Ackattack is offline   Reply With Quote
Old 04-02-2008, 08:25 AM   #6
El Jay
Re: wheel hop
That looks like an "AAWWWWWW CRAP!!!" from where I'm sitting.
Old 04-02-2008, 05:45 PM   #7
Psycho71
Psycho71's Avatar
Re: wheel hop
I 2nd that.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 04-02-2008, 06:28 PM   #8
greasy68
greasy68's Avatar
Re: wheel hop
That ujoint looks rough. 3 out of 4 isn't bad is it? I have no wheel hop on my leaf sping truck. Maybe I am just lucky.
Mike
68 C10 LWB midnight blue metallic
307ci, 700R4, HEI
front discs, leaf spring rear
tilt steering wheel, stock ride height, rally wheels,
2007 Dodge Charger(Hemi)
greasy68 is offline   Reply With Quote
Old 04-02-2008, 07:40 PM   #9
joedoozer
is Certifiable
joedoozer's Avatar
Re: wheel hop
Yeah wheel hop is shocks. Shocks only purpose are to slow the reaction of the spring. A bouncing spring doesn't sound very slow to me. Oh and nice u-joint . Was it a front or a rear?
1972 Chevy C10 LWB 350 Auto
Blue with a white roof.
joedoozer is offline   Reply With Quote
Old 04-02-2008, 07:42 PM   #10
joedoozer
is Certifiable
joedoozer's Avatar
Re: wheel hop
Oh and not trying to hijack the thread but I gotta ask . Why did you choose the av pic greasy68? I have a hockey buddy in Germany that has the same pic . He chose his because he looks like that in the pic . Just curious.
Old 04-02-2008, 08:41 PM   #11
whitelightenin69
Re: wheel hop
shocks are only about 1 year old so I don't think they are the problem, I was wondering if I might have worn out trailing arm bushings causing it to have axle wrap like in leave spring supension.....
Old 04-02-2008, 09:21 PM   #12
joedoozer
is Certifiable
joedoozer's Avatar
Re: wheel hop
Its possible, but I don't think it would have the same reaction like a leaf would. The wrap or twist of the axle actually changes the leaf spring. Just give the truck a really good shove. It should go down, up, then settle. Nothing more.
Old 04-02-2008, 11:56 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: wheel hop
If the shocks are new, I would blame the bushings. I KNOW the bushings in the burb are waisted, and the only time I have tried hard to do it in the burb, I got some wheel hop.
Old 04-03-2008, 03:28 AM   #14
Ackattack
Ackattack's Avatar
Re: wheel hop
yeah, I broke the rear u joint at the drag strip. I removed a leaf or two (can't remember) to lower it....which also increased axle wrap. So when I did a good enough burnout to get the tires to stick, it let loose.
Old 04-03-2008, 05:04 AM   #15
beautimus
beautimus's Avatar
Re: wheel hop
well, it could be shocks, i agree., but, if the trailing arms are separating, they could be bowing apart, and causing the wheel hop, possibly.
let me explain why i say this. (i know it sounds kookie) i had a 68 gto, with 3 2 barrels, 40 and automatic, the car just wouldn't hook up right. i raise the lower shock mount on the right side to plant the tire a little more firmly. and then it would wheel hop like crazy. i thought, man i just cant win. so i put the shock mount back in the stock location. but the wheel hop still wont go away. then i notice that the upper links to the factory 4 bar setup are bowed.
so, then i pulled them out, reshaped and boxed them with some plate so they can't bow. wheel hop is gone!!! then i moved the shock mount back up and the car launches right !!! SO thats why i am wondering could the trailing arms be seperating and bowing apart under load. if so you should be able to see where the trailing arms are taking on a bowed apart look where the two halves of the arm join. but then again, i could be way way off the mark here. it just another thing you might look at.
good luck, tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
