Old 04-02-2008, 05:29 AM   #1
rcs72
671 Blower?
How hard is it to install a small block with a 671 blower under the hood of a 55-59?
rcs72 is offline   Reply With Quote
Old 04-02-2008, 05:36 AM   #2
Kim57
Kim57's Avatar
Re: 671 Blower?
One of the plusses of these trucks is the amount of room under the hood. Every one I've ever seen with one goes in with no problems.
Kim
Kim57 is offline   Reply With Quote
Old 04-02-2008, 03:21 PM   #3
entourageguy
Yellow truck club
entourageguy's Avatar
Re: 671 Blower?
Check out some pics of Bob's red prostreet58 truck in this thread
http://67-72chevytrucks.com/vboard/s...d.php?t=242860
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 04-02-2008, 09:05 PM   #4
rcs72
Re: 671 Blower?
It looks like Bob's pro-street you would not be able to close a hood the engine. Maybe without the scoop, but it looks like it would be real close. Any other pics?
Old 04-02-2008, 11:11 PM   #5
poncho_villa
poncho_villa's Avatar
Re: 671 Blower?
I was going to go with a Weiand street blower on mine. Measured out just fine with lots of room. Didn't go with it because I didn't have enough room between the harmonic balancer and the rad for the lower blower pulley. Is the 671 much bigger than a street blower? If you can find the dimensions of them, then you have something to compare.
58 Apache short fleetside ona 64 chassis:
poncho_villa is offline   Reply With Quote
Old 04-05-2008, 12:41 AM   #6
prostreeter58
prostreeter58's Avatar
Re: 671 Blower?
You are correct, I have a hood cut out to allow the "hat" to protrude through it. However, I have raised my motor up as much as possible. If you are still at the stock height I believe it will clear with no problem. Of course it depends on what you top your carbs off with. I am thinking about changing to the EFT on the blower, then it will close with all sorts of room if you wanted to run a hood. My preference is to run without the hood. Hell, that stuff is just too pretty to cover up.........
prostreeter58 is offline   Reply With Quote
