Old 04-02-2008, 06:44 AM   #1
retselgerg
retselgerg's Avatar
Intake install question.(aggravated with my 69)
just seems like nothing works out for me, my dad rides this truck as his driver for 8 years with a wore out 200 dollar 305, and never had any problems out of it. when he gave it to me i invested (or thought i did anyway) in a new motor, intake, carb, waterpump, new belts and hoses, new heater core, new 4 core radiator, new headers, and all the tune up crap (most of it twice) and i cant even get it to were i can go cruise in it, today i finally got to finish wiring it up, and when i was routing the wires i noticed a few place where the intake was leaking, ( i guess that was my small miss) i have no choice but to take it off, and and get the proper 7201 edelbrock gaskets and reseal it, what should be my method in attacking this, torque pattern, Black silicone usage, etc....
-ya know my dad gave me a good platform, i mean nearly everthing on this truck is new and whats not new is of good quality, but id almost just sell out because i dont think i can ever get that damn rolling wreck dependable or even ridable..........
--G.Lester
"OLE BLUE" Goodwrench 350, 5speed, Tilt, PS, PB,
"some guys got into cars for money or girls but i got into cars because of the cars" -Jay Leno
retselgerg is offline   Reply With Quote
Old 04-02-2008, 06:47 AM   #2
ed2552
ed2552's Avatar
Re: Intake install question.(aggravated with my 69)
Use silicone on the ends and the corners, the stock gaskets will just fight you and leak. I think you torque it from the centers out in a criss cross pattern, but don't quote me on that
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-02-2008, 07:15 AM   #3
HoupPhotography
Definitly, take the rubber front and rear gaskets and throw them out, put about an 1\8 inch of rtv silicone on the ends, LET IT SET A FEW MINUTES so it skins over, then placethe intake back on. I'm pretty sure it's criss cross from the center too, but a book with specifics will help you a ton, good luck man!
HoupPhotography is offline   Reply With Quote
Old 04-02-2008, 07:16 AM   #4
rick0312
rick0312's Avatar
i just installed mine. I used felpro gaskets and high temp rtv silicone around the water ports and a healthy 1/4" bead on the china walls, and a goober in all four corners where the gaskets meets the walls. check out the edelbrock instructions for torque pattern.
http://static.summitracing.com/globa...ldfor57-86.pdf
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 04-02-2008, 07:43 AM   #5
retselgerg
retselgerg's Avatar
i heard a few ppl at work talkin about not even using the end gaskets, so would that be safe?
Old 04-02-2008, 07:54 AM   #6
Longhorn321
Size Matters
Longhorn321's Avatar
I think you should sell out....cheap! Just kidding, don't give up! With all that new stuff you can't be too far from having a really nice ride. Once you get that last little thing tweaked and it purrs like a kitten, you're gonna be so proud and feel like a million bucks. The thing about these trucks is ....well they're old! You gotta have patience but when you finally figure out what has been buggin you the reward is soooo worth it. Hang in ther buddy and remember, you got lots of help here.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 04-02-2008, 08:31 AM   #7
HoupPhotography
Yes it is safe, it's really the best insurance for the intake not leaking in that area. Those rubber gaskets move around and can give you a migrane.
Old 04-02-2008, 08:55 AM   #8
berencam
berencam's Avatar
What i did was cut the heads of 4 old intake bolts and screwed them into the heads. Then spread my rtv silicone on the end gaskets, and placed them down, then spread silicone on the intake gaskets. Once you spread all over the surface of the gasket i slid them over the studs and pressed them down. I let them sit for about 30 minutes then added my gob at each corner and dropped the intake down onto the studs. You have to cut 2 studs real short and set one side of the intake on first then the other on the side with short studs. Once your done thread a couple bolts, pull the studs and torque down. if you use studs and let the silicone set up a bit you wont have the gaskets moving around.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 04-02-2008, 11:11 PM   #9
chris71
chris71's Avatar
just to clarify, dont use them but use silcone or rtv instead of the end gaskets. just dont throw out the end gaskets and not use silcone/rtv on the ends
'55 3100 2nd series short-bed stepside
'70 Corvette coupe stingray
'71 Chevelle 2-dr coupe SS clone
'71 C10 long-bed fleetside
'83 long-haired brunette wife
chris71 is offline   Reply With Quote
Old 04-02-2008, 11:50 PM   #10
chev74
Addicted to Chevy
chev74's Avatar
glad you cleared that up for him. i have installed all my intakes without the endgaskets and just use RTV, but its hard to remember for the new guys what exactly you need to do step-by-step
chev74 is offline   Reply With Quote
Old 04-03-2008, 12:16 AM   #11
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Make sure you are using 1.25 long bolts….
http://67-72chevytrucks.com/vboard/s...d.php?t=282379
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-03-2008, 03:47 AM   #12
Sammy
Different torque specs for the eldebrock alum intake manifold too. Don't use the factory manifold torque. Plus 1/4" silicone on front rear w/out rubber gaskets to insure it spreads out. Additionally if U use high speed gasket set pay close attention to water jackets some U have to cut out.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-03-2008, 06:14 AM   #13
retselgerg
retselgerg's Avatar
i guess i need to locate the torque specs from edelbrock
Old 04-03-2008, 06:57 AM   #14
Super-Dave
Super-Dave's Avatar
No one has said anything about locktite. I had some bolts come loose also, and put locktite and never had the problems again. Aluminum and steel heat and cool at different rates so the bolts will come loose. Learned this the hard way. HEHE
Super-Dave is offline   Reply With Quote
Old 04-03-2008, 07:52 AM   #15
72lb4x4
Don't feel too bad. With all that you replaced, its hard to get everything perfect even if you didn't make a mistake.
The rubber end bits on the intakes are famous for leaking. You aren't the first.
72lb4x4 is offline   Reply With Quote
Old 04-03-2008, 03:47 PM   #16
Sammy
Later today I will post the install torque recommended by eldebrock sheet I have in the garage along with the sequence.
Old 04-03-2008, 05:16 PM   #17
Sammy
Here this is for the performer intake hope it helps.
Old 04-03-2008, 09:52 PM   #18
Myself
Aluminum heats up faster than cast iron. Use the block offs(for the heat passage) provided with the intake gaskets to increase performance a little. It helps keep your intake charge cooler and doesn't affect driveability.
Myself is online now   Reply With Quote
Old 04-04-2008, 01:09 AM   #19
BarryB
BarryB's Avatar
I don't think it was mentioned, But I'll state this fact. Aluminum and cast iron heat up and cool down differently Aluminum heats ups quicker but gets rid of the heat faster. So what I am trying to say. If you use regular intake gaskets, it doesn't matter how you put in on it's gunna leak sometime.
They make special gaskets for this application. These gaskets are more forgiving when the different heat factors come into play.
I also use the copper gasket spray on mine. That stuff works miracles. I use it on all my torqued gaskets, Heads, Intakes.
Oh and another thing that is commonly missed. You need to put some silicone on the threads of your bolts. because oil has been know to seep threw the threads.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 04-04-2008, 07:33 AM   #20
retselgerg
retselgerg's Avatar
I'll pick up some loctite tomorrow on my home from school...BTW i got the old one removed, even without loctite, the bolts all seemed to be tight, i hope it goes on as fast as it came off...........ANyone know to what ft lb to torque it to?
Old 04-04-2008, 07:37 AM   #21
retselgerg
retselgerg's Avatar
i have talked to alot of ppl at work about this, and im hearing alot of the same stuff so that is good,
and just for clarify, No RTV of the gaskets that are between the intake and heads?
Old 04-04-2008, 07:45 AM   #22
rick0312
rick0312's Avatar
the instructions that came with my edel said to torque to 25ft/lbs. make sure you follow the sequence.
Old 04-08-2008, 05:50 AM   #23
BarryB
BarryB's Avatar
25ft lbs sounds right. No your don't use RTV on the intake gaskets.
I don't even use the front and rear rubber gaskets. I just put a good thick line of RTV gasket maker across the front and rear. For the gaskets I use the copper spray. Really helps to adhere to the heads and intake, but that is my preference.
If you use the loctite. use the The blue not red. You might need to remove the bolts someday.
Two rules in life.
