Old 04-02-2008, 10:08 AM   #1
powerbench
powerbench's Avatar
Leaf to coil swap...Again
Ok, this has been asked a million times i'am sure.I took the trailing arms the brackets off the cross member for the trailing arms, the panhard bracket and the lower shock mounts.Do i need to take the shock cross member off the frame? do i need the reinforcement plate above the panhard bracket? Does any body have any detailed pics of a leaf spring truck rear frame? I would look at my own ,but it's at a friends shop locked up 35 miles away.
powerbench is offline   Reply With Quote
Old 04-02-2008, 02:00 PM   #2
tommypic
tommypic's Avatar
Re: Leaf to coil swap...Again
I want to know the same thing . I have a SWB GMC frame but I want trailing arms lowering alot easier . I would just buy a SWB trailing arm frame if I could find 1 close . I will watch this keep posted if you find pics
tommypic is offline   Reply With Quote
