Old 05-06-2002, 11:17 PM   #1
Johns70
Johns70's Avatar
Post 396 update rocker arm rattle
i posted awhile back saying i got the bb rebuild put back in the truck and fired up,but had a rocker arm rattle that i could not find.well it turns out after changing the oil two times,found metal in it again less than 500 miles on the motor. i noticed the distibutor was groaling when i was messing with the timing.took the dist. out and found a chewed up gear,that bothered me so i figured what the h#ll i'll pull the intake and check the cam lobes and lifters ,ahha i found the rattle that would not go away,very back lifter and lobe by the dist. flat as a possum on the white line,yes we have a few of them here in aberdeen wa. called summit talked to them and have to ship the cam and lifters back for a exchange replacment at there cost.don't know if i should stick with the crane cams now what do you guys think? or should i go with a comp cam?
project 70 chev swb rebuilt 396bb{402}rebuilt th-400 3.73 limited slip 4/5 drop
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 05-06-2002, 11:27 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
At there cost? How long you had it? You called crane? They have a good name and good rep. Give them a holler, see what they say.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
My name is Andy...not Randy...I'm in Ohio...Not Illinois...close enough?
Columbus Ohio
Old 05-07-2002, 12:18 AM   #3
BIG ORANGE
BIG ORANGE's Avatar
Wink
Hey John I built a 402 which is a 396 bored 030 over and I put a comp 270h cam lifters and pushrods and rollertip rockers and it works great,give it a thought!
1971 chevy suburban (BIG ORANGE)
1970,68,90 swb Little BUCKS one day
67/72 truck parts bought/sold
LIFE IS GOOD,THANK GOD FOR IT!
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
