Old 10-30-2002, 05:38 PM   #1
GMC71k20
body lift
i want more lift and a body lift is the cheapest way to do it. i already have a 4 inch suspension lift. what things will i have to change for the body lift? all i can think of is the e-brake line, is there anything else? how can you correct the bumpers being so low? will the clutch linkage be fine? what about steering coloumn?
thanks, bob
GMC71k20 is offline   Reply With Quote
Old 10-31-2002, 02:32 AM   #2
Tuffold72
well, depending on how much lift you want, but say 3. On my 68 I put a 3 inch and had some bad angles on the steering shaft, so I had it modified with a ujoint. It would still bolt up, but it really pulled on the rag joint. For the added length you will need to melt out the nylon roll pins in the steering shaft allowing it to slide down to meet up with the box. The clutch rod will have to be lengthend or you wont have any clutch pedal travel. For the brake lines you can carfuly uncoil the line from the master cylinder for the needed slack. You will probably have to cut off the lower portion of your fan housing for clearence to. If your running a automatic, yor linkages will have to be readjusted. I had to cut the transfercase lever hole about a inch back, or It wouldnt go into 4 lo. Thats about all I can remember doing off hand. On a side note, after all that work I took the body biscuts out after 3 months. I hated the extra body roll I got from it. For a cheap but better lift, I would consider getting a pair of front shackles made up about 2 inches longer then stock for 1 inch lift. and adding a add a leaf for the rear or a block. You may want to watch out for any wires, E brake cables etc. that may get pulled out when your jacking the body up. Good luck
Tuffold72 is offline   Reply With Quote
Old 10-31-2002, 04:19 PM   #3
GMC71k20
thanks for all the info, was the body roll really that bad? how was installing the body lift?
Old 10-31-2002, 07:44 PM   #4
Mudder
Mudder's Avatar
Good idea
to lube the threads on all the bolts a few days before you do this. May even think about new bolts and using a torch if they are rusted pretty good.
Mudder is offline   Reply With Quote
Old 10-31-2002, 11:48 PM   #5
GMC71k20
thanks, any brands that i should look for?
Old 10-31-2002, 11:59 PM   #6
Mudder
Mudder's Avatar
not sure
of that many companies making them.
Old 11-01-2002, 09:28 AM   #7
6869704X4
New bolts came with my kit. If your lifting it the front cab bolts need to come out. They are spot welded in. At least mine were. A cut-off wheel did the trick there.
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 11-14-2002, 04:08 PM   #8
wrathchild
LIKE 'EM BIG AND TOPLESS
wrathchild's Avatar
Performance Accessories.....
They sell body lifts...just recently bought one for my '70K5
wrathchild is offline   Reply With Quote
Old 11-14-2002, 10:25 PM   #9
GMC71k20
how is the quality of it? how did you get something to re-adjust your bumpers to stock location? that sounds like a *****in ride you have, got any pics?
Old 11-15-2002, 10:34 PM   #10
6869704X4
Performance Accessories. Thats the kit I used. Im happy with it. Didnt come with new bumper brackets so Im on my own there.
