Old 04-02-2008, 04:22 PM   #1
N2TRUX
Happy to be here
N2TRUX's Avatar
AOL pics for Scoti
Scoti this is not exactly what your looking for but it's all I have on file. I'll try o get some pics this week and post them up for you.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-02-2008, 10:53 PM   #2
SCOTI
SCOTI's Avatar
Re: AOL pics for Scoti
I can't remember, did Roger have to relocate the pass side shock? I can't see how there's room for the shock stud on the side of the frame where the bag would mount.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-03-2008, 07:11 AM   #3
shortchev
shortchev's Avatar
N2TRUX I sent you a message asking the same question.
Pete
shortchev is offline   Reply With Quote
Old 04-03-2008, 09:08 AM   #4
SCOTI
SCOTI's Avatar
Ken, I spoke w/Roger & he confirmed that he did 'flip' the pass side shock to use the ART kit.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-03-2008, 07:49 PM   #5
69face
69face's Avatar
you have to make another lower bracket or just flip and reweld it. i used 2x4 3/16" steel and notched it appropriately to match the contour of the rear end and it works fine so far. you can drill a hole in the rear after determining the correct position from a equal point on both sides. you will have to clearance the frame in the same manner as the drivers side(at least i had to) or the shock will rub the frame. new shocjs come with the studs to mount the shock, so you can measure the hole diameter off of that. good luck!
""A bagged vehicle is only as good as it's wheel/tire combo!" -getlowness!
my build thread http://67-72chevytrucks.com/vboard/s...=223747:metal:
I'M SO SO CAL!
69face is offline   Reply With Quote
Old 04-03-2008, 08:58 PM   #6
SCOTI
SCOTI's Avatar
Thanks for sharing. I had an idea on what it would take but I'm going a different route.
I could spend $300 for the ART AOL kit + a little more for materials to relocate the shock or I could use some small dbl convoluted bags I already have & spend the same money toward the materials making upper bag brackets that attatch to the c-notch plates.
The fab time is roughly the same so that's a wash & I already have the bags so they're paid for. I figure for <$30, I'll try to make my own. If it doesn't work, I'll get the ART kit & relocate the shock.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
