04-03-2008, 01:00 AM | #1 |
Proportioning Valve?
Moving right along with the disk conversion & brake line replacement. The master cylinder to prop valve lines that came with the brake line kit, does not match up with the original Prop Valve I got from the donor. The lines fit without the mounting bracket. Is it necessary to have the prop valve mounted on a bracket?
1997 GMC Sierra Ext 1965 Mustang |
04-03-2008, 01:17 AM | #2 |
67-72 Addict!
Re: Proportioning Valve?
Wow Steve that looks good! I would use a bracket. Isn't there enough flex in the lines to make it work?. I had a heck of a time with mine also but I finally got it. Maybe you could fab up a trick bracket? That MC looks different than mine.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 04-03-2008 at 01:18 AM. |
04-03-2008, 01:18 AM | #3 |
Phone's ringin Dude.
Mine doesnt have a bracket. Not sayin you should use this POS as an example, though! By the way, I've got a new booster, MC, and prop valve on the way to get rid of this eyesore, so leave me alone!
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
04-03-2008, 01:23 AM | #4 | |
Maybe I'll make some kinda bracket up. The brake line kit went in nice. No bending needed. I hope to have this job wrapped up by the weekend.
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 04-03-2008 at 01:24 AM. |
04-03-2008, 01:28 AM | #5 |
67-72 Addict!
They look really nice! I see you already got the control arms back in too.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
04-03-2008, 02:33 AM | #6 |
Just the left side. Hope to do the right tomorrow......
04-03-2008, 04:56 AM | #7 |
Nothing to see here.....
Very nice and clean! I mounted my prop valve on a bracket, but with the rigidity of lines, I think you'll be fine??? maybe not...
Doug THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten". The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson Last edited by tcb-1; 04-03-2008 at 05:38 AM. |
04-03-2008, 05:07 AM | #8 |
vibration and flex over time will cause the lines to crack and fail usually at a most inoportune time// save an oak tree some grief make a bracket
04-03-2008, 05:19 AM | #9 |
I am a Referee of life.
I agree with cdowns.If you didn't need to mount it the factory would not have gone to the expense.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-03-2008, 03:25 PM | #10 | |
Maybe I'll get a piece of "Maple" and make a bracket. Kidding aside, maybe it would be best to make a bracket for it.......
1997 GMC Sierra Ext 1965 Mustang Last edited by 70GMCer; 04-03-2008 at 03:30 PM. |
