Old 04-03-2008, 02:09 AM   #1
68gmsee
Active Member
68gmsee's Avatar
Bug season is here. Need Ideas for screening
I took my truck out for a nighttime test drive and picked up some moths and other assorted bugs on my radiator. In the spring we have a problem with grasshoppers, moths, love bugs, etc.
What are you all using for screens and where did you place it? Right behind the grill or in front of the radiator?
68gmsee is offline   Reply With Quote
Old 04-03-2008, 03:28 AM   #2
wibilly
wibilly's Avatar
Re: Bug season is here. Need Ideas for screening
i just use window screen in front of the radiator but want to have a edge soen on and snaps like a tonue cover to remove for cleaning
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 04-03-2008, 04:22 AM   #3
68gmsee
Active Member
68gmsee's Avatar
wibilly, I was thinking of using window screening myself but felt it might be too restrictive. Does it cause your truck to run warmer than normal?
