Old 04-03-2008, 03:43 AM   #1
gottwake
gottwake's Avatar
Whats the wheel base for 2wd blazer?
Im looking for the measurement between the Center of front and rear wheel.
Blazer Project
gottwake is offline   Reply With Quote
Old 04-03-2008, 04:00 AM   #2
gottwake
gottwake's Avatar
Re: Whats the wheel base for 2wd blazer?
I actually found it at 104". Whats the deal with that "factory assembly instruction manual" not listing it? They show 4 different frames none say 104".
Blazer Project
Old 04-03-2008, 04:46 AM   #3
bagged74
its just $$$$$
bagged74's Avatar
for some reason i was thinking 105, but i cant say for sure.
bagged74 is offline   Reply With Quote
Old 04-03-2008, 04:59 AM   #4
cdowns
cdowns's Avatar
it varies according to years
Old 04-04-2008, 07:37 AM   #5
68burb
69 to 72 is 104.5" and 73 - 91 is 106.5"
1968 K10 burb- on it's way to being C10 sporting a 454 th400 and LTZ 20's
1995 K2500 Burb as daily driver 350 with 193K miles
1994 K1500 Silverado ECSB building a TBI 350 for it 330 horse
68burb is offline   Reply With Quote
Old 04-04-2008, 07:50 AM   #6
gottwake
gottwake's Avatar
I was an inch off...thanks
Blazer Project
Old 04-05-2008, 12:09 AM   #7
68burb
the front wheels aren't centered in the wells either.
Old 04-13-2008, 02:27 AM   #8
jkade
jkade's Avatar
Yes 104.5 is what mine "was", if you are going low the rear needs moved back and the front forward to be centered in the wheel wells.
jkade is offline   Reply With Quote
Old 04-13-2008, 06:42 AM   #9
gottwake
gottwake's Avatar
So I center the rear and front when I have the truck on the frame(on the ground-real low)?
Blazer Project
Old 04-13-2008, 03:09 PM   #10
jkade
jkade's Avatar
I would set them when I had it at ride height or that is how I did mine and with the body on. It will be a pretty big project to move the front forward if using the stock suspension but I made my own c4 corvette stuff so I just positioned the crossmember where I wanted it and moved the trailing arm crossmember back on the rear. On the rear you will have to move all the related things back also. Good luck and this will make things look a ton better, most people spend all this money lowering the trucks and don't move the suspension around and it looks like crap in my book.JM2C I think if you go with a dropmember on the front it will move the centerline of the wheel forward so that may be the way to go on the front.
Old 04-13-2008, 03:24 PM   #11
bagged74
its just $$$$$
bagged74's Avatar
dropmember up front will center the wheels. longer trailing arms in the rear also works well.
