![]() Join Date: Oct 2005
Dag Blasted A/c!!!
Well here it is getting warm again and my a/c which I spent way to much on last summer is not working again. It seems to have leaked down while I had the engine out and was rebuilding it. I am so tired of putting freon in this da!! thing and it not cooling the truck down to a comfortable temp that I am about ready to set a match to it.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod. ![]() |
Re: Dag Blasted A/c!!!
You are going to have to find the leak and repair it.Check all the fittings with soap and look for bubbles if you dont have a propper leak detector.It doesn't take much of a leak to make a car a/c unit go low or flat.I would look for any oil on the fittings thats more than likely where the leak will be. Refrigerant and the oil are missable meaning the oil travels with the gas, oil will mean there is a leak.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 04-03-2008 at 06:30 AM. |
![]() Join Date: Nov 2004
I personally HATE doing this, but it may be best to take it to a qualified shop (one that does A/C only) and have them do a leak test. After that you can fix it! Then I'd recommend taking it back to have it evacuated and filled. I took mine to an A/C only shop after I finished the VA kit, they evacuated it, then filled it, no leaks and it's friggin cold.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
Last summer I took it in and the shop put the die in it to find the leak. We found that it was leaking from around the pressure switch. After backing it off a little it quit leaking but it never seemed to cool very good unless there was humidity in the air in the morning after the sun was up and getting hot outside it would quit cooling.
I have looked for the visible oil leaks but don't see any anywhere in the system. I guess I will take it back again to try and find it again. Thanks for the help guys. 67 if your'e ever in columbia let me know. maybe we could get together and talk trucks.
Gettin By on Gettin By
Are you running 134 in the stock system with the stock compressor??
I only make it to columbia a couple times a year now a days
![]() Hope you get 'er fixed. It SUCKS not having A/C, especially in Columbia!!!
Yep, we're the armpit of the south. kinda down in a hole and it gets hot. Not like being up in greenville or greer for sure. I'll get it fixed one way or the other.just hate having to spend money I dont have to do so.
Check the lines that go under or on the side of the battery. There's a fitting where the line goes through the firwall that can be hard to see. Also, the line itself is crimped and the crimp is hard to see.
"brand new second-hand"
Just had my a/c on my 96 Impala SS recharged because it had a leak-this was the second time for the same problem-turns out the shraider valve ( like the one's in the wheels etc) was made of plastic and breaks very easy-our trucks are probably metal but they still can leak......my 2 cents!!
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
