Tire Selection - Black or white
Blackwall or white letters out?
http://www.picturetrail.com/gallery/...52&uid=2902753 I had the tires mounted black out but then thought the white letters would add a good contrast. Not too late as these go back for balancing tomorrow. I had two sizes mounted for trial fit - 235-70-15 and 255-70-15. The 235s are what I will be going with. |
Re: Tire Selection - Black or white
White in black showing(outside). My.02, unless you go Wide whites.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
Yellow truck club
You should put a side picture of your truck on the photo shop forum and get them to put some wide whites on it. You might be surprises on how it looks.
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
The wide whites do look good on these trucks but that is not the look I am going for at this time. I have decided to stay with the black walls but can always swap them around at a later date.
Thanks for the replies |
polishing a turd
i like the black walls
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
Yellow truck club
Do those rims have any trim ring or center cap?
