rusty bolts- need help
I am currenly in the dissassembly stage of my bed and have two new bedsides ret to go. I got the tailgate off and the front panel unbolted with no issues, however, the bolts that are in the inside "angle" are small cariage bolts and after a few turns, the bolt and the nut turn together and make no progress. So, does any one have any tips on how I get get these things off quick like? I wont be re-using them so the more destructive the better, Thanx.
69 shorty w/ 67 front clip ![]() |
Tasty Cakes!
Re: rusty bolts- need help
Use an angle grinder? Or drill out the bolt heads? Hacksaw? Torch?
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
Cantankerous Geezer
If you have a welder you can weld a nut on the bolt head.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
![]() Join Date: Sep 2005
pb blaster is your friend
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
wow! thanx for the feedback guys!! I was thinking about a torch and a air chisel, but some of your suggestions may be a little more do-able.
you may be able to tighten the up and keep tighting them till they bust off. I do this all the time to get rust bolts off on these boxes
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
BlahBlahBlah
On small bolts like that if you can get a vice grips on em, nose grip not a side grip, sometimes you can just rock em back and forth and they will break off.
Too bad both sides are spinning. The tighten em till they break is another good way, as suggested already. |
Just tighten them about 1/2 turn-they will break-----easy to do.
![]() Join Date: Feb 2001
2 words - oxygen, acetylene. Whenever I pull a bed or take one apart, I go ahead and get my torch rig out. I usually cut the nuts off without even trying to wrench them off - especially wood beds!!
Joshua
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
huh ???
I took a small grinder and cut a slot so a friend could hold them with a big flat screw driver...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
![]() Join Date: Jan 2006
