04-03-2008, 09:48 AM | #1 |
235-327
Just wondering what all I will need to convert my old 60
4x4 over to a 327 from a 235 and does anybody make a motor mount for a swap like this or do I have to fabricate something, also I want this to look as factory as possible What do I do about the clucth I want to keep it hydraulic but the bellhousing I got has the fork coming through the drivers side, original is out the pass side, do I just do a hydraulic throwout or what Thanks in advance,Andrew
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
04-04-2008, 04:46 AM | #2 |
Re: 235-327
Hi Andrew,
I only have a few minutes right now, but I can answer one of your questions: http://www.novak-adapt.com/catalog/kit_hcrc.htm
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
04-04-2008, 06:21 AM | #3 |
Re: 235-327
that is alot of money to spend for nothing,
just move the slave cyl over to the left side. you may have to do a little fab work and move the line over. now there may have been a reason for mounting it orig on passenger side. ishould be a problem on a 4 x 4 but on a 2 x 4 the torsion bar setup may have caused the reason to move it over to the passenger side. the other option is to find a v8 bellhousing with the pass side access for the clutch mechanism and shouldn't cost you $200.00 and you will have accomplished something other than just ordering up something from a store ron |
04-04-2008, 07:18 AM | #4 |
Re: 235-327
Edited by mod**
All wanted to buy must be in the classified section. To post you ad, you need to be a subscriber. Click here to subscribe
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 Last edited by Fred T; 04-04-2008 at 07:43 AM. |
