Old 04-03-2008, 02:57 PM   #1
tds
passenger side gas tank removal
has any removed the passenger side gas tank but left the driver side tank installed and functional? i don't believe my passenger side unit works any more so i was just gonna take it out and maybe mount my batteries or air tanks there. so if any one has done it that would be great if you have some advice.
1981 - C-10 SCSB
Planning on putting this thing on it's rocker!
tds is offline   Reply With Quote
Old 04-03-2008, 06:52 PM   #2
andresco50
andresco50's Avatar
Re: passenger side gas tank removal
It have 2 supports with 4 bolts each that's all!!
2001 silverado 2wd
2003 silverado 4wd
1975 scottsdale c10 (project)
andresco50 is offline   Reply With Quote
Old 04-03-2008, 06:54 PM   #3
babyJay
Arrived on a Pale Horse
babyJay's Avatar
and wear some good safety glasses...
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-03-2008, 08:54 PM   #4
tds
Yea I saw the bolts. I was more wondering about any wires or fuel plumbing. Any idea on that? Thanks for the help guys
1981 - C-10 SCSB
Old 04-04-2008, 03:01 PM   #5
tds
any body?
1981 - C-10 SCSB
Old 04-04-2008, 03:03 PM   #6
babyJay
babyJay's Avatar
Just remove the diverter valve and all wiring. Run the lines that go from the engine bay to the diverter straight to the tank. That's what I did in my '79 shortie. I left the switch in place on the dash so there wouldn't be a hole, then used it to fire up my KC Daylighters.
Jason
89 R3500 CC SRW
Old 04-04-2008, 08:54 PM   #7
tds
Where was that valve located? Thanks for the help.
1981 - C-10 SCSB
Old 04-04-2008, 09:18 PM   #8
babyJay
babyJay's Avatar
You'll have to pull the bed. It's on the driver's side, half under the cab, half under the bed.
Jason
89 R3500 CC SRW
Old 04-04-2008, 11:44 PM   #9
tds
So like directly above the driver side gas tank?
1981 - C-10 SCSB
Old 04-05-2008, 12:53 AM   #10
86 GMG
you can remove the valve with out removing the bed if you are not able to get help to lift personally its less work to crawl under there and remove it it has two bolts that bolt through the frame and it has a metal panel that covers it to keep it protected it is really easy to remove just dont under estimate your capabilties.
square body trucks an addiction or an investment either way they consume all my extra time and money
86 GMG is offline   Reply With Quote
