Old 04-03-2008, 05:14 PM   #1
aventur1
aventur1's Avatar
PO Heater cable miss routing?
So how does this heater cable suppose to be routed? It's the one for the fan that goes to the bottom. Also what's the best way to lube all you cables? He had duck tape on the seam also and the bottom left vent hole covered up with duck tape, wonder why he covered the little square hole under neath on the right?
aventur1 is offline   Reply With Quote
Old 04-03-2008, 08:00 PM   #2
prg machine
prg machine's Avatar
Re: PO Heater cable miss routing?
simply put that cable BEHIND the box and to the bottom lever from Behind the box. Lube cables with www.gibbsbrandlubricant.com
69 K-20 cloned to a 67 with front clip and some other stuff.
383 .040 over
Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears:
prg machine is offline   Reply With Quote
Old 04-04-2008, 12:01 AM   #3
aventur1
aventur1's Avatar
Thanks, it will look a lot better!!!
Old 04-04-2008, 12:24 AM   #4
prg machine
I had a problem with mine popping off of the lever and had to bend the cable eye end to keep it in position.
383 .040 over
Old 04-04-2008, 03:08 AM   #5
aventur1
aventur1's Avatar
ok, I'll check it and maybe also bend the end, it just did not look right in the first place
Old 04-04-2008, 06:38 AM   #6
prg machine
yea it is a little tough to get around over the top but that is where it belongs. I just got done putting mine in, but the glove box is out of the way and staying that way until i am darn sure everything works after I get the truck on the road.
383 .040 over
Old 04-04-2008, 06:56 AM   #7
aventur1
aventur1's Avatar
Glove box out, cool I have a new one to put back in!
Old 04-04-2008, 07:23 AM   #8
LockDoc
The Older Generation
LockDoc's Avatar
I posted some pictures in this thread....
http://67-72chevytrucks.com/vboard/s...=heater+cables
LockDoc
Leon
Old 04-04-2008, 07:26 AM   #9
LockDoc
LockDoc's Avatar
There are push on clips that hold the cables on the control levers you can see them in this pic. The same clips hold the cables on the heater box levers.
LockDoc
Leon
Old 04-04-2008, 10:32 AM   #10
Wreckless_71
Wreckless_71's Avatar
LocDoc just read my mind... there are those clips to hold the cables on, all of mine are broken so i just bent the cables like PRG machine said. and the cable does go behind the air boxes.
1972 K10 4" lift, 35’s, 383 stroker, 700r4, current project.
1971 C10 3"/5" static drop, 355/350. "La Bamba.” The current daily driver.
Wreckless_71 is offline   Reply With Quote
Old 04-04-2008, 03:50 PM   #11
aventur1
aventur1's Avatar
Looks like with all the info I better get busy this weekend and get it behind the box so I can clean the box and get that duck tape sticky stuff off and paint it up. The slight seperation is more than likely why the PO taped it, maybe I could use black caulk on the seem before I paint.
Old 04-04-2008, 07:59 PM   #12
prg machine
I don't realy get why the thing was duct taped together. The whole design leaks everywhere anyway.........I would just clean it and paint it. There is a flapper door in there to direct the airflow up to the defroster and it isn't perfect, so some air gets bypassed to the floor area anyhow.. I usualy split the differences between defrost and floor after getting de-iced in the morning anyhow, so a little leak here and there is nothing to worry about.
383 .040 over
Old 04-04-2008, 11:01 PM   #13
aventur1
aventur1's Avatar
I found that out. On floor setting it still defrosts, LOL!!!
