Old 10-30-2002, 09:11 PM   #1
dion
72 Cheyenne
dion's Avatar
Lowering a 3/4 LWB
Leaf rear, seems easy enough but the front looks like a lot of work. Okay, so I get the new springs (good place to get them from?) and then take the top control arm off? Any tips/suggestions? Thanks.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 10-30-2002, 09:18 PM   #2
special70gmc
special70gmc's Avatar
sorry i m not sure bout your questions but i do have a question how much r u droppin it i wanna drop mine but not sure how much
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 10-30-2002, 09:46 PM   #3
dion
72 Cheyenne
dion's Avatar
Well my plan is to get new rims, I have 17's now, I'm thinking 16 or even 15's and a bit smaller tire, after that I will decide how low to go. I don't want a "Slammed" truck just a little lower than stock.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 10-30-2002, 11:12 PM   #4
hughnews1
8 lug 17 " ??????
hi i have a 71 3/4 from AZ .. are your wheels 8 lugs 17 " LMK please
hugh
hughnews1 is offline   Reply With Quote
Old 10-30-2002, 11:37 PM   #5
dion
72 Cheyenne
dion's Avatar
Huge
Yes, check out the pics on my sig. Eagle Wheels.
Burnout
Idle
1972Cheyenne
1966/67Stouts
Old 10-31-2002, 02:24 PM   #6
jflem3
jflem3's Avatar
I had eight lug 17" on my 90 burb Mickey thompson Classic 2's. 17X9 there are even some 8- lug 20's around. we used the on a SEMA suburban I did Enkei's 20X9 nice 5-spokes.
Jim
Davisburg, MI
69 Camaro SS LT-1/6-spd
71 C-20custom deluxe burb 402/400
(gonna get back to it)
72 C-10base burb 350/3-spd
79-VW Scirocco GT-3 race car 2.0L/5-spd
02 chevy suburban LT Supercharged dropped on 22's
jflem3 is offline   Reply With Quote
Old 10-31-2002, 02:25 PM   #7
jflem3
jflem3's Avatar
Why would you back down from 17's if you already have them?
Jim
Davisburg, MI
Old 10-31-2002, 02:26 PM   #8
Riles72
I recently lowered my truck (72 half ton stepside) 2.5 in the front and 4 in the rear. sits nice and pretty now. I got my stuff from Classic Engineering, and If I remember right, they have a 3/4 ton lowering kit. You might give them a call and get a magazine, or ask someone on the board if they know for sure.
72 Chevy short stepside
350/350
tilt, vintage air a/c
sunset Orange Metallic paint
Early Classic 2.5/4 drop
eagle series 211 wheels
Riles72 is offline   Reply With Quote
Old 10-31-2002, 02:33 PM   #9
COBALT
COBALT's Avatar
Early Classic Enterprises
For the front you'll need drop spindles + new springs depending on the drop you want. Brakes may be an issue, but the front-end components can be re-used if they're in good shape and you had disk brakes to begin with.
Don't know about leaf rear suspension, though. You may have to worry about shock relocation.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-31-2002, 03:17 PM   #10
Bustedup
I have a '71 3/4 ton that I lowered about 5 years ago. I have the re-located ball joint on the lower control arms plus 2 inch lower springs. In the rear I have 4+ lower springs. I had to use a bolt in C notch to keep from hitting the 1" bump stops. I am running 275 50 R16 BFG's all the way around and it doesn't rub anywhere. I use this truck to push race cars and is set up for cornering and I like the fact I have heavy duty suspension parts that won't fail. If you have a coil rear there is another source for parts, Winston Cup. I have used parts, axle pads, panhard bar and have a Ford9in from Yates racing waiting to go in.
PS I like to tell people "Anyone can do a half ton"
Bustedup is offline   Reply With Quote
Old 11-01-2002, 04:06 PM   #11
WB72
Before and After
WB72's Avatar
Man, am I glad to see someone else is doing thee same thing that I am doing. I would like a 2.5"/ 4"drop. Would you suggest a lowered spring in the front and a combo of spring and block in the back?
I would like to see photos of 3/4 tons dropped with stock rims. Does anyone have some?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
