resto body guy
87 pickup woes!
i have a 1987 1/2 ton TBI 350 chevy pickup and i can't seem to keep taillight fuse not from blowing! i have cleaned the tailight sockets replaced the bulbs and cleaned the grounds. and replace the headlight switch with another one i had. still no luck!
what else is on that circuit?? any ideas help.... Thanks, David |
Re: 87 pickup woes!
Check the wires from the housing all the way to the front. There may be a bare spot that is grounding out.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Re: 87 pickup woes!
I had a truck in high school that did this until it finally got on my nerves to the point I had to do something . I found that the wires were pinched between the frame and the bed . Lifted the bed a little to release the wires , rerouted them , and the problem was taken care of . Once I started looking for the problem , it only took a short time to find the problem . Frank
Born and proudly residing in a Red State ! |
Arrived on a Pale Horse
Re: 87 pickup woes!
The license plate light is on it, and maybe a trailor plug if your truck is equipped with one.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW Last edited by babyJay; 04-04-2008 at 03:08 PM. |
Re: 87 pickup woes!
the dash lights are alson on that circuit
