well after checking all over the place I finally decided to go with a steel gas tank I finally ordered it had everything planned to put it in and wouldn't u know it we got 5" of snow the day it was delivered
![]() Adam ![]() |
![]() Join Date: May 2007
Re: got the new gas tank
who'd you get it from? I just installed one last weekend and had to do a lot of work arounds I took plenty of pics and will be posting them. -Jason
- Jason ![]() ![]() |
I picked it up from lmc truck for 173.00 tank and shipping everything i've done and seen says all i have to do is remove the old filler tube from the old tank to the new tank but like anything else it proboably won't work that way.
Adam ![]() |
Post Whore
![]() Join Date: Feb 2000
When I got my new tank of course it wouldn't fit so I took it and had the old neck soldered onto the new tank - got home and the darn thing still wouldn't fit.
Broke out the hack saw and cut the old neck off the new tank and used a piece of 1 3/8" fuel hose to attach my old neck to the short fitting on the new tank. The portion I cut off the old filler neck is about 1 1/2" behind that little tab that you see on the side of the filler neck that is used to secure the smaller vent line. For reference, you can see how I folded that tab flat in the pics of the tank installed. Here are a couple pics of the old tank and the new tank ![]() ![]() ![]() ![]() Here are a couple pics to show how I used the old tank's filler neck. About a 4" piece of hose goes from the new tanks existing filler neck and attaches to the bent piece that I cut off my old tank, then it connects to the long piece that will go up the side of the Blazer. ![]() ![]() ![]() Hope this info helps you with your tank.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 04-04-2008 at 05:55 PM. |
Where did you find 1 3/8ths fuel line? All I could find was 1 1/2.
Post Whore
A local industrial rubber hose supply company had it in stock and in a fuel grade.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
i did some measuring and my old filler tube is 1 1/4 all I could find is 1 1/2 so now i'm off to find some more parts
![]() Adam ![]() |
It's 1 3/8" and napa has it straight peices. If you go to a super flex hose all I have found is 1 1/4" and 1 1/2". Some guys had luck with the marine stuff. But they don't have boats where I live. -Jason.
