Old 04-04-2008, 07:52 AM   #1
rick0312
rick0312's Avatar
What size alt?
What size altenator are you running? I need to purchase a new one and was wondering if I should go with more amps. My current alt is 61 amp rating. I don't have air or electric fuel pump or fans. What amperage would you guys reccomend..thanks
69 C10 LWB GM 350 crate motor, 3.73 rearend
rick0312 is offline   Reply With Quote
Old 04-04-2008, 08:06 AM   #2
El Jay
Gone to greener pastures
Re: What size alt?
Like a lot of things, I'm of the mind that bigger is always better.
You now have my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-04-2008, 10:44 AM   #3
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: What size alt?
Being as you need to replace it anyways I'd go with at least a 100 amp model- you never know what sort of electrical do-dads you'll be inclined to add in the future, but at least you'll know the alt. is up to snuff.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 04-04-2008, 02:54 PM   #4
Re: What size alt?
61A is the largest alternator offered in these trucks and is more than adequate for a loaded truck.It is also the maximum windings that will fit the original case.I found this out when having my alternator built for use with a snow plow.I had the 49A and that highest rating he could get out of it was equal to GM`s 61A.You`d have to go to the later right-side alternator.When converting to the later two wire internal regulator type alternators you`ll most likely be jumping up in amp rating.I ended up using one from a 6.2 diesel which is 100A.
Old 04-04-2008, 09:53 PM   #5
Green Machine
Green Machine's Avatar
Re: What size alt?
Just my personal opinion, but I would not go larger that around 60 amps or so because the wire to the battery is only 12 ga. If you had a really low battery I suspect a 100 amp charge would fry the wire or the fusable link (16 ga) that is supposed to be in there just before the battery.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
