Old 10-30-2002, 10:52 PM   #1
low 84
low 84's Avatar
? for dave
what is the name of that polish stuff you use on yur truck that makes it glassy?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 10-30-2002, 11:05 PM   #2
Big Paul
Iamnotanofficerofthelaw
Big Paul's Avatar
Exclamation
ZAINO!!!
Alot of show car guys use the stuff. Makes okay paint look like $10,000 paint!
~Paul~
'96 C1500 Silverado- Vortec 5.0L/Exhaust/Stock
'87 S-10 Ext Cab- 2.8L/700r4
KIA Caught fire 12/7/03
Big Paul is offline   Reply With Quote
Old 10-30-2002, 11:28 PM   #3
c10scotty
~THE SILVER BULLET~
c10scotty's Avatar
hmmm, what is it? just a wax? how much does it cost? the "mystic silver" on my truck is lookin more like grey these days and i would like to find a way to spiff that paint up a little to hold me over till it gets painted.
~1980 c10 chevy scottsdale~
~2.5/4 drop 305/th350c~
c10scotty is offline   Reply With Quote
Old 10-30-2002, 11:36 PM   #4
Big Paul
Big Paul's Avatar
Scotty, Zaino is quite expensive. I'm not too sure on that, but i'm thinking its more then some other products.
I've heard good things about Meguiars Gold Class series of waxes and polishes.
I'm sure if you do there complete polish system. Clay bar to clean paint, wax, polish and some elbow grease you would get some great results. And i'm sure its cheaper then Zaino.
www.meguiars.com
If you go there, go to there products section. Then look through there consumer steps 1-5 on cleaning and taking care of the paint. That should help you out.
~Paul~
Old 10-31-2002, 11:44 AM   #5
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
You dont even want to get me started on how much better Zaino is that the others out there.....in fact there really are no "others" Seeing as how they are all waxes or silicones.....Zaino is a fully synthetic clearcoat polish. No abrasives, no fillers, and no carnuba AT ALL!~!
Plain and simple fact....carnuba yellows and melts off. If you dont believe me, set a candle out on blacktop for a week in 100 degree weather and watch what happens to it....duh..it melts....why..because its made of wax. So that is the easiest way to explain why wax is a waste of time. Not to mention all waxes have Silicone fillers in them that appear to make the scratches disappear. If you dont believe this ....go get some Pledge or wesson oil and rub it on your paint....it will shine like a diamond in a Goats @$$....but it *like wax* will attract dust like no other.
Another added *benefit* to wax is the harsh abrasives and chemicals that will over time scratch your finish and wear it down...thus the need for the silicone to fill it back in so you dont see it.
Also, Wax "dents" if you will...bugs and such embed themselves into it as where Zaino provides a barrier to the elements...It physically bonds to the clearcoat and you will be amazed at how easy bugs and road goo come off.
Zaino also has anti static properties and UV filters to protect your paint....its so high tech its rediculous....The price...dont let it scare you...its nothing like the wax your used to using...."Less is More" in the case of Zaino..the thinner the coat the better. And it lasts up to 6 months with one application. So as an idea of how long it lasts....I detail cars on the side...along with mine and the Grand Am....They get it at very minimum 1x-4x a month depending on time/carshows/weather. and it will last me almost 8-10 months. Along with the other 30-40 cars a year I do.
Zaino "stacks" on top of each new coat to build up the barrier, along with the added shine, it over time hides the fine scratches and such....notice, it does not remove them but masks them to the human eye. Waxes cannot do this as each time you reapply a new coat, the abrasives and chemicals strip the last coat and just put on a new one...causing more scratches and damage.
For those of you that dont believe me....feel free to call Sal Zaino at his # on the website...I speak to him on a regular basis....ask him about what happened with me to switch me over to Zaino....You will be surprised.
I know this is a lot to take in at once but its all true.
Seriously give hime a call...he is a super nice guy.!
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 10-31-2002, 12:27 PM   #6
70sChevys
Where do you get this polish? Is it different to apply from regular car wax?
Kelly C. Hanna
MMCC & Southern Bowties Club
Hanna Woodworks
Classic Chevy Country
70sChevys is offline   Reply With Quote
Old 10-31-2002, 12:41 PM   #7
LOHRTBT
LOHRTBT's Avatar
www.zainobros.com
it applies much the same but there is a starting process that needs to be adhered to in order to get proper results. After that...its the easiest system in the world to use and the fastest.
~Dave~
Old 10-31-2002, 04:16 PM   #8
PHOENIX
I dont know if thats the look im going for
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-31-2002, 06:49 PM   #9
LOHRTBT
LOHRTBT's Avatar
lmao!!
~Dave~
