04-04-2008, 09:17 PM | #1 |
Gettin By on Gettin By
polish for the dash cluster clear plastic??
Well i pulled my dash cluster apart last night and got all the needles painted, bulbs replaced, painted the bessle, but my clear plastic piece *not sure what its called* that has the numbers painted on it *ie speedo and fuel level* is scratched up and painted on.
Whats the best polish out there for getting this thing clear and nice?? I figured just some light rubbing compound or regular paint polish. Any idea's or recomendations? ttt |
04-04-2008, 09:35 PM | #2 |
Size Matters
Re: polish for the dash cluster clear plastic??
I don't know any name brands but there is such a thing as plastic polish for just such an application. I work for BMW and we used to sell a product for polishing the instrument clusters and other clear plastic parts (rear windows of convertibles). It worked great. I suspect you can find something like it at advance auto parts or something like that. I would not use compound....to harsh. Car wax might be ok but I would check it on one of the places that is behind the bezel first to make sure it does not leave a haze or something.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
04-04-2008, 09:36 PM | #3 |
Go to a plastics supply company/distributor that sells acylic sheets like plexiglass, etc. The one we use in Denver is Regal Plastics. They will sell a polishing compound that will be best suited for the lens. Just a fair warning, I don't believe any of them will give you like new results.
04-04-2008, 09:36 PM | #4 |
I thnk that plastic is too soft - your best bet is just to order another one.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
04-04-2008, 09:36 PM | #5 |
They make polish specifically for clear plastics, i have some but dont remember the brand, it should easily remove the scratches and polish it up, i dont know about removing the paint though...
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
04-04-2008, 09:48 PM | #6 |
Hello
I use a product called Plexus its made for Jeep soft tops it takes the scratches out of the windows. I also use it on my Motorcycle hemet face sheilds it works great. I don't think it will harm the paint on your dash. |
04-05-2008, 12:08 AM | #7 |
Size Matters
Oh yeah, I forgot to mention that they are available and IMO they are pretty cheap.
04-05-2008, 12:09 AM | #8 |
its all about the +6 inches
the numbers and letters are on the inside of the lens... be carefull around them, they CAN be polished off. More likely, you'd wear a spot real thin without paying attention and the number would look retarded after you got done. Not much work needs done on the inside anyways.
I have always used mothers wheel polish. Always have it laying around, and it does so good, I never considered spending more money on another product. |
04-05-2008, 12:09 AM | #9 |
Novus Plastic polish ... best thing EVER for plastic. Like Longhorn Man said, be very very careful on the side with the silk screening on it.
04-05-2008, 12:14 AM | #10 |
I just did mine using this meguiars
It worked great, I removed the lens and did it by hand, wasn't brave enough to try it on a buffing wheel but would like to try it. I bought the stuff at Walmart, like $6 if I remember correctly. Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
04-05-2008, 12:31 AM | #11 |
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
04-05-2008, 12:41 AM | #12 |
The back side with the numbers is fine. Just the front. I took some 2000 grit paper to some hidden spots last night. Just need to polish the front.
I agree with Longhorn, lookin to spend 3 or 4$ rather then 30. Thansk for the info guys. I'll see if i can get some pics tonight after we get back from the circus with the kids. |
04-05-2008, 05:21 AM | #13 |
Gone to greener pastures
Don't laff.
Tooth paste. Not a tooth gel, but plain ol' fashioned tooth paste & a very soft cloth.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
04-05-2008, 05:58 AM | #14 |
I just used some Meguiars cleaner wax on the lens on my S10. Came out great!
04-05-2008, 07:18 AM | #15 |
Born Psycho
Crest toothpaste, not gel but the plain old white gritty stuff. it works great and is cheap too.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-05-2008, 08:25 AM | #16 |
Well i hit the local Walmart and got the Meguair's PlastX. $3.97 a 10oz bottle. Worked like a charm. I successfully ruined the last of the good dish towels, but it was worth it, "Baby, it says use a soft dry cloth".
That old plastic is brittle. I got the cracking and breaking rubbed out where you can't see it on a galloping horse with some 2000 grit sandpaper and this PlastX, but the camera flash makes them very visible. I plan on trying this stuff on my parking light with a drimell buffing wheel Sunday. Might work. My repaint isn't anything fancy, but i think it'll work in a black and white interior. BTW, the 72k on the odm is really 172k. Figured someone would notice. Last edited by jayharrell; 04-05-2008 at 08:27 AM. |
04-05-2008, 08:46 AM | #17 | |
I can understand why the wifey would get P.O.'ed. Back in the olden days, before disposables, nothing was better than old diapers. They got laundered 2, 3, 4 times a week, or more.
04-05-2008, 03:46 PM | #18 | |
that is the best stuff to restore plastic parts and polish it. I use it on safety glasses
04-05-2008, 03:53 PM | #19 | |
so easy a caveman can do it...
04-05-2008, 05:05 PM | #20 |
I've used Brasso, it is a very mild abrasive, also works great on watch crystals.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
04-05-2008, 05:57 PM | #21 |
Happy Camper
Looks good, wanna trade?
RIP El Jay! Love you brother! |
04-05-2008, 06:22 PM | #22 | |
As for the tade, you wouldn't want this one. I just rattle canned it. Its not near nice enough for anyones truck. Hell i should probably just throw it in the trash. lol |
04-05-2008, 06:41 PM | #23 | |
The youngest is 30, so he hasn't worn diapers for a while.
04-05-2008, 08:32 PM | #24 |
Permatex Headlight Lens Restoration Kit $ 13 - 15 dollars. This works really good. It is made for plastic headlight lens to make them clear again. If has three different stages.
1972 GMC Sierra Grande 3/4 Ton 4x4 1970 Mercury Cougar XR7 1943 Farmall M |
04-05-2008, 08:37 PM | #25 |
I used Plast-X on mine, too. I still have a couple of deeper scratches, so I may try the 2000-grit sandpaper on those. Other than the deep scratches, Plast-X did a great job of removing the light scratches and clearing up the lens. Like some of the others mentioned, I also used it on my wife's 98 Camry (271,000+ miles) headlights to remove the yellowing and clear them up.
HomerJ
67 C-10 LWB "Cow-butt-spotted" (neighbor's term) - work in progress. 350/TH400/3.73 67 Chevelle SS Clone 454/TH400/3.73 |
