Old 04-05-2008, 01:08 AM   #1
6bangr
rear axle i.d location
its a 69 c10 stepside. but when i got it, he told me it had a 3/4 ton rear end. i just want to know what i got. thanx
6bangr is offline   Reply With Quote
Old 04-05-2008, 01:48 AM   #2
nightmare
nightmare's Avatar
Re: rear axle i.d location
well, the easiest way would be to count the number of lugs on one of the rear wheels. if it's 8, then it's a 3/4 ton rear. if it's 6, then it's a 1/2 ton rear. now if there was any work done, i.e. replaced the axle shafts with 5 lug shafts, it could be anything. also, you could ID the center section by whether it's a Corp 14 bolt or 12 bolt by the cover plate on the differential. could be anything though. Could you post some pics?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is online now   Reply With Quote
Old 04-05-2008, 01:57 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A lot of people see 6 lugs, and they will swear up and down it's a 3/4 ton.
If you can post photos, we can tell you exactly what it is.
Only 3 types came in the 67 - 72, coperate 12 bolt and a handfull of Dana rears in 1/2 ton, and then the corperate axle/eaton diff HO52 or dana in 3/4 ton, and then the axle/eaton diff HO72 in one ton trucks.
Old 04-05-2008, 02:39 AM   #4
6bangr
its a 6 lugger and a 12 bolt. so the label in the glove box tells the truth? it says it has a 307 rear end ratio. is this good or bad for city driving?
oh yeah and how do you post pics on a thread?
Old 04-05-2008, 03:17 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Go to this forum and scroll down until you see the threads on posting pictures. There are two or three of them.
http://67-72chevytrucks.com/vboard/s...d.php?t=262547
I just put a 3.07/8 in the white truck and it drives great.
LockDoc
Leon
