![]() Join Date: Dec 2007
Front bumper brackets help?
I think this has been covered before yet i cannot find it. I am having troubles mounting my front bumper the drivers side bracket is hitting the power steering gear box... Do I need to cut the bracket??? If so anyone have a photo of how much should be cut?? Sorry if this is a repost.
go cyclones
Re: Front bumper brackets help?
Did you buy an after market bracket? It should miss our box, im sure someone will chime in.
The Older Generation
Yes, I think it needs to be notched on some year trucks. I don't know how much. By the way, welcome to the board from Iowa. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-05-2008 at 04:18 PM. |
I had the brackets switched.....fix the issue when i changed them to the right side
![]() Join Date: Feb 2004
See you had it in you the whole time
BTW ![]()
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" Last edited by 72armyswbtruck; 04-07-2008 at 12:36 AM. |
There are a few differences between the applications. For example a 67 bumper bracket on drivers side typically was not recessed for the PS box as PS was a different style and used a different box than a PS box..67 used ram assists PS.
68-72 2 wd GMC should be the same. 68-70 2 wd Chev should be the same as the 68-72 GMC 2wd. 4x4 are unto themselves and 68-72 gmc 4x4 are same as 68-70 Chev 4wd. 4x4 71-72 chev are their own style also...longer due to signal lights in bumper. You may run into brackets that dont have a recessed clearance for the PS box because the truck was shipped with brackets not originally ordered with PS option. Rod
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
#7 | |
The Brackets came of a 71 gmc with ps, and went on a 68 with ps. Thanks for so much info it is great to know!! |
